The Garden
Page 29 of 35 [854 Posts]
Goto page: Previous 1, 2, 3, ..., 27, 28, 29, 30, 31, 32, 33, 34, 35 Next
PostPosted: Mon Apr 21, 2025 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
a couple more photos
I got 2 Fuchsias for in the deep shade corner where hardly anything else seems to survive
There is still a cyclamen growing in that pot as well but even that one struggles.
 Filesize:  286.29 KB
 Viewed:  117 Time(s)
The Erysimum linifolium which I got last year did not only survive but is also flowering now.
 Filesize:  334.22 KB
 Viewed:  122 Time(s)
 Filesize:  151.57 KB
 Viewed:  88 Time(s)
a bit more of the sedum has survived in here than I thought, I love these mini worlds.
 Filesize:  252.57 KB
 Viewed:  108 Time(s)
bees!, not a lot but happy to see at least some return
 Filesize:  323.51 KB
 Viewed:  132 Time(s)
PostPosted: Wed Apr 23, 2025 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
foliage dwarf
Phacelia is doing great, especially now that we've been getting a bit of rain. I've added the sticks for extra support.
 Filesize:  331.73 KB
 Viewed:  123 Time(s)
Epimedium appears to happy in that spot.
(the small plastic pot has Primula elatior seedlings)
 Filesize:  287.04 KB
 Viewed:  129 Time(s)
 Filesize:  320.22 KB
 Viewed:  128 Time(s)
its wearing some flowers of the Brunnera
 Filesize:  262.27 KB
 Viewed:  109 Time(s)
for some reason my camera refused to focus on it
 Filesize:  237.8 KB
 Viewed:  124 Time(s)
PostPosted: Wed Apr 23, 2025 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Razz
 Filesize:  450.83 KB
 Viewed:  122 Time(s)
 Filesize:  444.74 KB
 Viewed:  113 Time(s)
 Filesize:  319.55 KB
 Viewed:  93 Time(s)
PostPosted: Wed Apr 23, 2025 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spring Cool
what btw is this thing?
That monkey in the other flower pot seems to want to know too Shocked
this device thing
 Filesize:  167.28 KB
 Viewed:  7287 Time(s)
PostPosted: Thu Apr 24, 2025 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a solar powered garden light.
One of the first ones I've ever bought and also one of the few that's still working.
I did replace the (rechargeable) battery a couple times, removed some corrosion and re-polished the solar panel.
I've had a bunch of other ones that usually don't last very long although I have been able to frankenstein some into working ones.
I also have some hanging glass ones in several colors that look more bulb shaped, they do actually work pretty well but I gave those
a bit of an upgrade.
They generally don't give off much light, they're more like lit objects, but this year I got some new ones that do actually give off
a surprising amount of light. They're the small white bulbs visible in this photo (there are 3 of those along the edge of my balcony)
I'll try to make an evening photo when we have some sunny days and they're charged up again.
(no monkeys btw, just some horrific looking gnomes)
 Filesize:  261.82 KB
 Viewed:  107 Time(s)
PostPosted: Thu Apr 24, 2025 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
meant this one ... it .. whatever it is .. seemed to look at the object .. which is no wonder i guess ... when it lights up at night Idea
Thought it it to be be something with water btw .. the light Laughing
gnomon ky
 Filesize:  48.69 KB
 Viewed:  7271 Time(s)
PostPosted: Fri Apr 25, 2025 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
There will be a solar powered water feature added to my balcony later on (if it still works).
I tested it last year but didn't really have a good spot for it, I had it out for most of the summer though.
This year I reserved a spot for it so it will be a bit hidden between the plants.
you can have a sneak peek here:
I do have a bit of standing water on my balcony already at the moment. Willows like to have their feet wet so I wanted to add
a saucer under the pot (also for stability since it's resting on another pot) and after looking around a bit I found an old frying pan
in one of my cupboards that had the right size. I keep filling it up with water every now and then and I placed a large pot shard
in it so insects have access to it and can climb out if needed.
 Filesize:  362.93 KB
 Viewed:  132 Time(s)
 Filesize:  228.39 KB
 Viewed:  121 Time(s)
 Filesize:  274.07 KB
 Viewed:  115 Time(s)
PostPosted: Fri Apr 25, 2025 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh .. that turned out to be a sneak pee though Laughing
Does it have a pump, or does it run on heat alone?
PostPosted: Fri Apr 25, 2025 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
It has a small electric pump powered by a solar panel (connected with a cable).
Initially it started out as a recirculating bird bath but that wasn't very practical and I don't think the birds ever made much use of it if any.
The hookah idea came later in a puff of smoke. I got the thing as a gift years ago but never used it and according to my calculations it should
work in reverse as a water feature. I did have to plug one hole and add a couple of O-rings for better waterproofing but other than that
it works great. It's very cheaply build though and I did notice some rust when I took it apart at the end of last year, but that was to be expected
because it is of course not meant to be used like this.
In the video it does indeed only trickle down in a single stream but when there is more sun the saucer at the top overflows on all sides
and the water runs down over the hookah itself. It's also practically silent when it does that.
 Filesize:  176.5 KB
 Viewed:  100 Time(s)
 Filesize:  165.31 KB
 Viewed:  110 Time(s)
there's a hole in the center that the water comes out of and when it flows over the edge it gets collected in the white bucket and recirculated.
 Filesize:  191.99 KB
 Viewed:  119 Time(s)
PostPosted: Mon Apr 28, 2025 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Idea
they're actually less bright then they appear in the photo but also give off more light, or at least that's what my eyes tell me
 Filesize:  71.18 KB
 Viewed:  122 Time(s)
 Filesize:  62.41 KB
 Viewed:  121 Time(s)
these have yellow LEDs (original was white)
 Filesize:  139.27 KB
 Viewed:  119 Time(s)
PostPosted: Mon Apr 28, 2025 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
flower
They grow up so fast. They almost tripled in size in the span of 4 days.
 Filesize:  292.41 KB
 Viewed:  133 Time(s)
the (blue) bells are ringing
 Filesize:  260.42 KB
 Viewed:  110 Time(s)
 Filesize:  319.9 KB
 Viewed:  103 Time(s)
PostPosted: Sat May 10, 2025 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
king
 Filesize:  375.56 KB
 Viewed:  120 Time(s)
 Filesize:  257.33 KB
 Viewed:  126 Time(s)
every garden needs some proper kitch
 Filesize:  211.35 KB
 Viewed:  123 Time(s)
the flowers on the other Fuchsia plant have also started to open.
I didn't know what color to expect but it wasn't this, I like it though.
 Filesize:  129.37 KB
 Viewed:  111 Time(s)
 Filesize:  131.02 KB
 Viewed:  107 Time(s)
PostPosted: Sat May 10, 2025 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
cherry
we've entered may so the peppers have been planted out
L>R: Fresno+, Ghost (Bhut jolokia), Fresno+, Carolina Reaper, Fresno+
 Filesize:  307.12 KB
 Viewed:  116 Time(s)
L>R: Fresno+, Ghost, Fresno+, Trinidad Scorpion, Frenso +
 Filesize:  286.31 KB
 Viewed:  116 Time(s)
We've had a week of warm 25C+ weather so I made use of that to get the Morning Glory seeds to germinate
 Filesize:  287.04 KB
 Viewed:  123 Time(s)
here's an inside out view through my kitchen window
 Filesize:  202.44 KB
 Viewed:  111 Time(s)
PostPosted: Sat May 10, 2025 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
haven't killed any Sedum yet sofar, it's actually growing pretty well.
I am using the one in the hanging planter more or less as an indicator for when to water them.
it has grown and spread out a bit
 Filesize:  222.68 KB
 Viewed:  113 Time(s)
The one in the photobox planter is looking especially nice.
Also the Leontopodium (Edelweis) is starting to produce flowers.
 Filesize:  266.21 KB
 Viewed:  114 Time(s)
 Filesize:  287.22 KB
 Viewed:  105 Time(s)
this one is also doing great and might keep flowering well into the summer
 Filesize:  181.14 KB
 Viewed:  107 Time(s)
PostPosted: Sat May 10, 2025 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
flowering Delosperma.
There should also be a white one mixed in with the pink one but unless/untill it flowers I have no idea if it's still alive.
 Filesize:  250.86 KB
 Viewed:  107 Time(s)
 Filesize:  276.31 KB
 Viewed:  118 Time(s)
 Filesize:  439.79 KB
 Viewed:  117 Time(s)
 Filesize:  471.35 KB
 Viewed:  121 Time(s)
Tagetes are also starting to flower
 Filesize:  482.89 KB
 Viewed:  112 Time(s)
PostPosted: Sat May 10, 2025 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
flower
so many flowers
(hardly any interested insects though)
I am happy to see that the Geranium robertianum (Herb-robert) with its pink flowers is finding its way through everything.
Tall one on the left side is Nepeta Cataria, aka Catnip
 Filesize:  401.93 KB
 Viewed:  113 Time(s)
 Filesize:  471.31 KB
 Viewed:  104 Time(s)
PostPosted: Wed May 14, 2025 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's alive, It's Alive!
 Filesize:  135.54 KB
 Viewed:  94 Time(s)
PostPosted: Wed May 14, 2025 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing nice flower too Cool
PostPosted: Thu May 15, 2025 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
First flower on the Leontopodium alpinum is starting to open up. I do like these fuzzy flowers that almost look like they're made out of felt.
It is being attacked by some leaf miner insect again, as was the one I had last year. I've tried to remove all the affected leaves and will keep
an eye on it. I don't mind if they want to snack a bit but last year they didn't leave much of the plant intact. It's also supporting an aphid
colony but you'll find those on a lot of plants around this time of the year and I am not too worried about those (yet).
 Filesize:  178.26 KB
 Viewed:  109 Time(s)
 Filesize:  195.23 KB
 Viewed:  98 Time(s)
 Filesize:  150.64 KB
 Viewed:  110 Time(s)
PostPosted: Thu May 15, 2025 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a different support for the Opuntia. I was using some sticks to keep it upright but that was more of a temporary thing until it got rooted.
It won't fall over now without any support but it's leaning a bit and it has decided to grow another section on top which could exacerbate the situation.
The copper looks very new and shiny at the moment but once it has developed a bit of a patina it should stand out less.
The section it grew last year did get somewhat etiolated because I didn't have a suitable sunny spot for it. I guess it'll become part of its life story
just as the scarring on the first section because I literally picked it up from the street.
 Filesize:  276.69 KB
 Viewed:  114 Time(s)
 Filesize:  193.56 KB
 Viewed:  115 Time(s)
 Filesize:  216.95 KB
 Viewed:  99 Time(s)
PostPosted: Thu May 15, 2025 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Salix caprea ‘Pendula’ seems to be content with its semi-sunny spot but does look a bit 'out of shape'.
Not that there is anything wrong with it but I was expecting that it would grow leaves directly from it's pendulous branches.
Instead it grows smaller branches from those branches and the leaves grow out of those.
As a result its shape is less defined at the moment but that's fine with me.
The Ajuga that I planted below it as a ground cover is, well,.. starting to cover more ground.
The snowdrop bulbs are also still in there but I am not sure if they'll like the wet conditions.
It might actually be more suitable for Anemones.
 Filesize:  380.93 KB
 Viewed:  113 Time(s)
 Filesize:  299.38 KB
 Viewed:  115 Time(s)
 Filesize:  282.36 KB
 Viewed:  100 Time(s)
I like the subtle traces of pink in the new growth
 Filesize:  267.01 KB
 Viewed:  115 Time(s)
PostPosted: Mon May 19, 2025 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
pink, yellow, white and now orange as well. Razz
forgot I had this one too, actually I am not even sure if I knew I had this one.
It is one of two small clumps that I removed from my herb planter and planted with the other alpine plants.
I initially thought it was 'coral carpet' Sedum but once it started growing it became clear it was more Delosperma.
As far as I know they don't come in blue but maybe I'll come across some Gentiana someday.
 Filesize:  151.05 KB
 Viewed:  116 Time(s)
PostPosted: Tue May 20, 2025 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
IT'S WORLD BEE DAY 2025 AND,.. I SAW A BEE!
ok, technically I saw it sunday but I can't keep my eyes on my balcony all day and I like to believe it returned for more.
It's still only 1 bee though but that's 1 more than last year.
It seemed to prefer the Erysimum but it also visited flowers on the Delosperma, Daisies and Tagetes.
I am particularly happy seeing it on the Tagetes because that's the reason I am growing an open single flower variety.
Since I now know that they are easy to grow inside under LED lights I bought more seeds for next year.
These are Tagetes patula nana in a mix of yellow/orange/red varieties. I will also collect seeds from the ones I am growing this year.
- here's a low quality out-of-focus video of it visiting some other flowers.
I also got a couple more plants, one of which was selected by a bumble bee.
I was just looking at some colorful short snapdragons when a bumble bee came by and crawled into one of the flowers,
so of course that's the plant that I took home with me (after the bee was gone). It's actually 2 different colored plants in a single pot.
The yellow one almost has a neon color, especially in the evening at sun set it appears very bright. The red one has some pink on
the back and also a bit of orange/yellow in it. I am not entirely sure where to place them but I think I only have one suitable spot left.
 Filesize:  127.75 KB
 Viewed:  104 Time(s)
 Filesize:  155.45 KB
 Viewed:  112 Time(s)
 Filesize:  211.27 KB
 Viewed:  98 Time(s)
bumble bee approved
 Filesize:  185.55 KB
 Viewed:  119 Time(s)
 Filesize:  123.01 KB
 Viewed:  106 Time(s)
PostPosted: Tue May 20, 2025 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess it made sense to plant them today and with that the whole planter is filled up.
They're almost lining up in height with the taller ones that I grew from seed last year (all white so far).
hmm, there is still one strawberry plant in there which I moved from the right side to the left because it was
literally getting overshadowed by all the other plants. But now it ended up between the snapdragons and the railing.
I might as well swap the two around and move the strawberry plant to the front.
well, anyway this is what it looks like now. The idea was to create a smörgåsbord of flowers for pollinators and I think
it's working out so far. Might have to give the hanging planter a bit of a haircut for summer, especially since it already dries
out pretty fast and that will get worse if the plants get bigger and the temperature higher.
 Filesize:  372.31 KB
 Viewed:  111 Time(s)
 Filesize:  416.29 KB
 Viewed:  100 Time(s)
 Filesize:  422.96 KB
 Viewed:  105 Time(s)
 Filesize:  404.99 KB
 Viewed:  102 Time(s)
 Filesize:  287.11 KB
 Viewed:  105 Time(s)
PostPosted: Tue May 20, 2025 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The snapdragons were more of an impulse buy but I also bought some plants that I did set out to get.
first of all Waldsteinia ternata aka barren strawberry which I got as a ground cover for the planter against the wall that has the ivy growing in it.
I've tried growing several plants in it before but so far without much luck, except for the ivy of course that is doing great. It's pretty much always in full
shade apart from a tiny bit of sun at the very end of the day and because of the ivy the soil can get rather dry on sunny days.
Waldsteinia ternata should be ok with full shade and can tolerate dry conditions. I am pretty sure I did try to grow one of those in there before without
success but this time I went all in and got a 6-pack. This doesn't leave a lot of room for them to grow except backwards towards the wall around the ivy
and maybe trailing a bit over the front. I did see some (mostly spend) flowers on them and they might still flower more this year.
Thunbergia alata I tried to grow this from seed last year but from the 6 seeds I had only 1 germinated. I did really like it but one plant wasn't
enough to have the impact I was hoping for. This year I got 12 seeds but again only 1 has germinated, at least so far, so I just bought one.
It did have to spend a little bit more than I'd like for an annual but although it is a single pot it actually had 6 plants in it, all of them larger than
I would be able to grow them at this time of year if I'd grew them from seed. And as a bonus it came with 3 nice sticks I can use as plant supports.
Initially I thought about separating them completely before planting out but the roots were rather fragile and I didn't want to risk damaging those
so I just planted the whole clump and than separated them out above ground. The one I grew from seed is planted in the center and its flowers might
have a different color because it came from a mix.
Dryopteris erythrosora aka Autumn fern. I do already have 2 ferns but although they don't exactly look dead neither of them has put out any
new fronds. I already had my eyes on getting an Autumn fern because I wanted something with different colored foliage, different as in not green.
With all the plants I already have there is quite a variety in shapes/sizes/textures of foliage but most of it is some shade of green.
An Autumn fern has foliage that starts out with a bronze/copper color and then fades to yellow before turning green.
Sempervivum 2 of them for the alpine planter. One of them is a large red one with pale green tips the other one a cluster of bright green ones
with dark red tips. The sedums in the alpine planter are doing better now that they are getting watered more frequently but I might have overdone it
a bit and now the sempervivums aren't happy, well except for one that is.
There is one more plant I'd like to add this year which is a foxglove. I got a really nice compact multi-stemmed flowering one at the beginning of June last
year but at the moment the only ones they had available were just small rosettes of leaves that are nowhere near flowering. When they're that small they
don't do well on my balcony so I'd rather wait and hope I can get one again later.
It has to grow in a bit but I like it already
 Filesize:  352.92 KB
 Viewed:  118 Time(s)
how it started
 Filesize:  250.45 KB
 Viewed:  104 Time(s)
how it's going
note that it's growing at the base of the obelisk that has the hanging planter at the top.
if it all works out they should meet and turn it into a tower of flower.
 Filesize:  271.2 KB
 Viewed:  102 Time(s)
such a pretty specimen.
 Filesize:  248.45 KB
 Viewed:  106 Time(s)
please ignore the sad looking Edelweiss on the left. It doesn't really like the heat (and it's in a small metal box) but perks right up again after a drink in the evening.
 Filesize:  438.24 KB
 Viewed:  114 Time(s)
