Streaming now
Midi to CV design -- Soliciting advice
Page 3 of 3 [59 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Wed Apr 10, 2019 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want to measure the speed of calculations, shouldn’t you measure the difference between a loop with and without the calculation?
like:
Code:
 while (1) {
        PORTC.6 = 1;
        PORTC.6 = 0;
and
Code:
 while (1) {
        PORTC.6 = 1;
        val1 = val1 / val2;
        PORTC.6 = 0;
my synth
PostPosted: Fri Apr 12, 2019 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
just want to say it's nice to see people having a respectful discussion. Some of the info is a bit over my head
but I might look into more if I want to make a midi2CV device myself Very Happy
cloudberry
PostPosted: Wed Sep 16, 2020 2:53 pm    Post subject: control change Reply with quote  Mark this post and the followings unread
I've been looking over this, and I'm trying to work out what 'control change' means. Does this mean continuous controllers etc? And, (cos my coding is, er, poor, and I may have overlooked the bleedin' obvious: it happens) I'm struggling to see how one assigns a particular CC to be output. How would I get it to output breath (CC#2), for example?
JovianPyx
Audio files: 224
PostPosted: Wed Sep 16, 2020 3:38 pm    Post subject: Re: control change Reply with quote  Mark this post and the followings unread
Control Change is a type of MIDI message. They all begin with hex Bx where x is the channel. Some control change messages are also continuous controllers messages others are switched controller messages. More Info
The structure of the messages is Bx NN VV where x is the channel, NN is the controller number and VV is the value for that controller. You need to know the controller number, construct the message and send it.
Time flies like a banana.
corruptio optimi pessima
cloudberry
PostPosted: Thu Sep 17, 2020 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
OK. Got it. But it's the code:
Code:
case midi::ControlChange:
        d1 = MIDI.getData1();
        d2 = MIDI.getData2(); // From 0 to 127
        // CC range from 0 to 4095 mV  Left shift d2 by 5 to scale from 0 to 4095,
        // and choose gain = 2X
        setVoltage(DAC2, 1, 1, d2<<5);  // DAC2, channel 1, gain = 2X
        break;
I can't see where MIDI.getData are being set to a particular CC value.
Audio files: 299
PostPosted: Thu Sep 17, 2020 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Let me try to explain the flow of stuff.
MIDI is an object, objects are entities with values and methods.
getData1() and getData2() are methods of the MIDI object, and a method is a function call oprating on an object. These are the abstract naming conventions.
The notation is Object.Method() - the parenthesis indicate a funtiion (or a method) call, and the dot indicates that a member of an object is being used. getData1() is a member of the MIDI object.
So, getData1() calls into the MIDI object to get some value from there. That value in turn is extracted from a received MIDI message, and the MIDI message got there because an external device sent it.
The code internal to the MIDI object looked into the received message and extracted the data from it, which it then stored away to be retreived later with the getData1() and getData2() calls.
Once the message is completely received the MIDI object calls into your code to eventually end up in the code fragment you posted. This is a common way to implement a driver in code, the MIDI driver in this case.
When you want to receive CC2 (breath controller) messages, there will need to be a MIDI transmitter sending such messages and usually that would be a breath controller device, such as a MIDI sax, but there are standalone breath controllers too, and some synths have one built in.
Now when you do not have or do not want a breath controller, your MIDI device might still be able to send other usable CC messages you could use - maybe CC7 for volume, but that is something to be looked up in the MIDI implementation chart of that device - and this should be in it's manual (as such is part of the MIDI specifications: MIDI devices should have an implementation chart in their manuals).
May this clear it up a bit :-)
cloudberry
PostPosted: Thu Sep 17, 2020 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank-you for the crash course!
Yes, this is for a wind controller (a WX11).
So this code grabs whatever CC passes through and spits it out to the DAC? That would work for a specific device I suppose.
Audio files: 299
PostPosted: Thu Sep 17, 2020 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yeah cool thing WX11, does CC2 alright, having one here too Very Happy
The code indeed seems to pick up any CC as is, as I do not see a selection on the CC number .. so you might want an extra condition .. probably on d1 .. so something like :
Code:
  if( d1 == 2)                      // To let trough CC2 messages only
  break;
cloudberry
PostPosted: Thu Sep 17, 2020 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again for your help!
