Useful shortcut for G2
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Sep 09, 2017 10:20 pm    Post subject: Useful shortcut for G2 Reply with quote  Mark this post and the followings unread
Hola,
I work a lot with shortcuts on the G2. Don't be affraid to use them!
"Shift + Variation" = Reset the variation. Practical to load the original parameters of a patch when moving too many parameters and want to return to the basic patch.
"Shift + Perf. Mode" = Loads the active slots in performance (.prf) and vice versa. Useful when you want to record the contents of the slots in performance or to translate a performance into 4 patches > 4 .pch2
"Copy/Paste + move a assigned knob from the Parameter Pages, after press Patch" = access all the parameters of a desired module quickly without having to scroll all the modules one by one in a patch.
"Copy + Active Slot (A to D)" = allows you to select a slot and access the 'parameter pages' knobs. But the piano, modwheel and pitchstick are affected ONLY to the other actives slots.
I will add more soon or/and tell me which are useful for you. Let me know if something is not clear because my english is not good.
Smile
