4017, how do you use it?
Page 1 of 1 [5 Posts]
Harry
PostPosted: Mon Apr 02, 2018 9:37 pm    Post subject: 4017, how do you use it? Reply with quote  Mark this post and the followings unread
This is a question for those of you using a standalone 4017 wired pin to jack, not in conjunction with other chips. I'm soldering one of these into my lunetta currently, but was very close to not including it because I was unsure how I would use it in a patch. If I'm being honest with myself I believe the blinky led element won me over more than creative sound possiblities. So I'm just wondering how do you use it in a patch? Like a sequencer, narrow pulse divider, controlling gates?
I just ordered more banana cables in anticipation Razz
Steveg
PostPosted: Tue Apr 03, 2018 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
You run it at tempo rates as a sequencer to trigger notes or percussion. or you can run it at audio rates and do something like put a pot on each output to create a wavetable kind of effect or you can use it as a rate divider with the proviso that the duty cycle will be 1/n where n is the divider amount.
piedwagtail
PostPosted: Tue Apr 03, 2018 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Polyrhythmic gates.
Same clock, two 4017s with different steps and different reset lengths ie. 1,3,8 of 10 against 2,4 of 7.
R
PostPosted: Tue Apr 03, 2018 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I often use a large part of my lunetta modules to create sequences and the 4017 is great for triggering other things.
It can give nice variations when set at different/odd stepcounts. Sometimes I just used it to get the timing right for something.
Make sure to include the CLK enable pin (13) in your built, it can be very useful .
Harry
PostPosted: Tue Apr 03, 2018 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two in parallel thats a good idea. No room on this machine for a 2nd 4017, maybe for 2.0.
Oh, was only including the clock and reset, I'll be sure to drill another hole for the inhibit since you recommend it.
