Joined: Nov 23, 2015 Posts: 1313 Location: Netherlands
Posted: Sun Dec 09, 2018 2:37 am Post subject:
Just another Transistor Ladder Filter Subject description: part from the net, part from me |
Yes, another transistor ladder filter.
A part from the net, a part from myself.
I have filters in my synth, built around a MAX26x programmable switched capacitor filter with a cv for frequency and q-factor (emphasis) as well midi input.
The downside is that when I set F0 to a lower frequency, the clock signal becomes audible, because F0=200 x Fclock.
So I decided to build a full analog filter, based on the moog transistor ladder filter.
When looking at the schematics of the well known transistor ladder filter I noticed that there always is a instrumentation amplifier made with either transistors or multiple opamps. So I thought why not use a real instrumentation amplifier?
So I added an instrumentation amplifier, an AD620, I know, concerning the price ....
The good news for me is that I can get samples from Analog Devices, so they cost me... nothing
I have not paired the transistors, but still it sounds good to me (untrained ears ) it is good ping-able, self oscillation is great too.
I have added a piece of perfboard to the pcb layout.
edit: updated schematic
Description: |
FM modulation of the filter |
 Download (listen) |
Filename: |
FM.wav |
Filesize: |
7.92 MB |
Downloaded: |
950 Time(s) |
Description: |
just a short pulse (about 2 msec) to the Audio input |
 Download (listen) |
Filename: |
pinging.wav |
Filesize: |
3.75 MB |
Downloaded: |
968 Time(s) |
Description: |
No audio input, just to the cv of the filter's F0, and playing with range and emplhasis potmeters |
 Download (listen) |
Filename: |
filter_self_oscillating.wav |
Filesize: |
4.31 MB |
Downloaded: |
938 Time(s) |
Description: |
 Download (listen) |
Filename: |
filter_norrmal.wav |
Filesize: |
7.03 MB |
Downloaded: |
951 Time(s) |
Description: |
updated version of the filter |
 Download (listen) |
Filename: |
schladderfilter_updated.pdf |
Filesize: |
1.47 MB |
Downloaded: |
658 Time(s) |
_________________ my synth Last edited by Grumble on Mon Apr 29, 2019 4:41 am; edited 2 times in total |
cslammy
Posted: Tue Dec 11, 2018 1:19 pm Post subject:
Looks good grumble!
Preguntas:
What would be involved you think in having this work with +/- 15V?
And have many CV ins (to set frequency)...for CV I guess I could slap a CV mixer (a TL072 and a few resistors) in front what is here?
Does the AD620 need to be something that "fancy"? Can it be say a TL071? _________________ Visit my AUDIODIWHY blog and website |
Posted: Tue Dec 11, 2018 2:33 pm Post subject:
Like I wrote in the first post, a part from the net, a part from me, and the left part of this filter is ‘borrowed’ from the net what means that I am not sure how to answer your first few questions.
About the ‘fancy’ AD620 it cannot be exchanged by a single opamp like the TL072 because it is a true instrumentation amplifier, NOT an opamp.
It could be replaced by a number of opamp configured as an instrumentation amplifier.
like this:
but that is just what I wanted to inprove on. _________________ my synth |
ixtern
Posted: Wed Dec 12, 2018 12:30 am Post subject:
cslammy wrote: | Looks good grumble!
Preguntas:
Does the AD620 need to be something that "fancy"? Can it be say a TL071? |
Just look at the other moog transistor ladder VCF clones. For example, yusynth version:
http://www.yusynth.net/Modular/Commun/MOOGVCF/Moogfilter-sch.jpg
You have +-15V and common TL072 plus four transistors instead of AD620.
And I think that Grumble's circuit should work even with TL071 or almost any contemporary op amp instead of AD620. Instrumentation amplifier is simply differential amplifier with very low offset/drift and high input impedance. AD620 additionally has one-resistor-set gain, what is not important here. So simple op amp in "difference amplifier" configuration should work (although it will have worse some parameters like offset/drift and input impedance), at least for prototyping. Of course you should do some cosmetic changes to the schematic as standard diff amp schema is not the same as AD620 application.
BTW input op amp impedance in Grumble circuit doesn't matter as there are 220 Ohm resistors at the inputs of AD620. So only offset/drift is better. |
Posted: Wed Dec 12, 2018 3:06 am Post subject:
ixtern wrote: |
Grumble wrote: | Oh just noticed that R31 and R32 are 100k NOT 220E ... |
and:
Grumble wrote: | About the ‘fancy’ AD620 it cannot be exchanged by a single opamp like the TL072 because it is a true instrumentation amplifier, NOT an opamp. |
You need a high input as seen from the ladder filter, even 100k is a little low, so I removed R31 and R32 and shorted C14 and C17 to get a better range.
These two resistors and C's where added because I thought that the difference between the transistors in the ladder would give a dc offset, but afterall it wasn't that bad, so I could remove the resistors and C's.
Also if you just replace the AD620 with a TL072 the gain is far to high, so my guess is that it wil oscillate. _________________ my synth |
ixtern
Posted: Wed Dec 12, 2018 3:44 am Post subject:
Grumble wrote: | ixtern wrote: |
and:
Also if you just replace the AD620 with a TL072 the gain is far to high, so my guess is that it wil oscillate. |
My bad with 220 Ohms but it doesn't change my conclusion. All JFET-input op amps have high enough input impedance so 100kOhm is not too much for them.
About gain you may be right. With 100kOhm at inputs you would need megaohms in loop what is not quite good. But TL072 and two-stage amp would do - first stage with low gain, second with desired gain as driven from low-impedance output. Oscillations can be prevented with small (10-50pF) capacitor in op amps feedback loop. |
Posted: Wed Dec 12, 2018 5:19 am Post subject:
Grumble wrote: | so I removed R31 and R32 and shorted C14 and C17 to get a better range. |
Just saying
The whole thing was just to see if an inamp would fit there, and it did, by no means I would force someone to use an expensive inamp where one could use a cheap LM324. _________________ my synth |
Hashtag Octothorpe
Joined: Jun 11, 2017 Posts: 57 Location: Grand Rapids MI
Posted: Sun Jan 27, 2019 2:56 pm Post subject:
Wow, I just came here to ask a question about transistor (diode) ladder filters and how to get the signal out of them without a noisy multiple-transistor amplifier!
I guess I'll create a new post...
[Link added by Blue Hell] For new post see : http://electro-music.com/forum/post-438887.html#438887 |
gabbagabi
Posted: Mon Jan 28, 2019 10:11 am Post subject:
ups, somehow i missed this thread
congratulations!
somethimes it has to be analog!
as far as i can see u have implemented a resonance vs. amplitude circuit, so
what i would like to ask: how good that works?
gabbagAbi |
Posted: Mon Jan 28, 2019 12:52 pm Post subject:
are you asking me? if so, just listen to the soundbites in the 1st post in this thread  _________________ my synth |
Hashtag Octothorpe
Posted: Fri Feb 15, 2019 10:09 pm Post subject:
I was trolling the internet cursing my obsession with the 303 diode ladder VCF when I found an example of a transistor ladder that used a LM13700 OTA where you've got the instrumentation amplifier. I can't find the schematic right now, but I believe the inputs were connected straight to the uprights of the ladders through a pair of capacitors, no ground reference, the linearizing pin was ignored and the "amplification" pin (1 or 16) was just tied high through a 47K resistor.
And for some reason they ignored the on-chip darlington pair and buffered the output with... a transistor??? I wish I could find the schematic because why would anybody do that
I'm definitely going to build this filter soon. I *LOVE* the sound! |
Posted: Fri Feb 15, 2019 11:29 pm Post subject:
Quote: | I can't find the schematic right now, but I believe the inputs were connected straight to the uprights of the ladders through a pair of capacitors, no ground reference, |
You doesn’t need a ground reference resistor because the input resistance of a LM13700 is typical 26kohm, which, as I understand, is quite low as seen from the filter. _________________ my synth |
