 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Benjolin Rungler Mod ?
Post new topic   Reply to topic Moderators: Rob
Page 1 of 1 [3 Posts]
gabrielcichero
PostPosted: Mon Mar 18, 2019 9:59 am    Post subject: Benjolin Rungler Mod ?
Subject description: mods for loop
i've made the Benjolin 1.
In a video i heard Rob suggesting a mod with a switch, to make the Rungler work fixed in a "loop mode", like a step seq..
Anyone has any idea how to do that?
okelk
PostPosted: Sat Mar 30, 2019 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Easy.
The rungler has two inputs from the oscillators.
If you take away the input that feeds into the XOR , the shift register just cycles the 8bits of data at the rate of the second oscillator.
In practice that means that you could add a switch switch between the oscillator and ground before the resistor that connects to the transistor.
...also if you don't ground it but connect it to V+ it inverts the data coming from the shift register and you get a longer loop that kind of goes up and down.
PostPosted: Sat Mar 30, 2019 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check "loop mod" on this page:
https://web.archive.org/web/20150311234517/http://casperelectronics.com/rungle-mods/
