R_Gol
Posted: Thu Oct 17, 2019 12:07 pm Post subject:
Noobie question about the Nord MM and midi |
Hi there,
So I just got the Nord MM and I'm super exited about it.
my setup is macbook pro os x mojave;
motu UltraLite mk4;
Novation Launch Control XL midi controller;
I manage to connect the pc in and out of the MM to the midi in and out of the Moto UltraLite MK4. with this connection I manage to edit and load patches from the editor to the nord MM.
my first question is: Why I can hear a sound only when I close the editor window?
when the editor window is open no audio is coming through.
Second question is: in the setup above - how can I connect the novation LaunchControl XL to map knobs of the MM ? I did not manage to do so. Do I need another midi device ?
Thanks for any help! |
Joined: Apr 03, 2004 Posts: 24508 Location: The Netherlands, Enschede
Posted: Thu Oct 17, 2019 3:52 pm Post subject:
Re: Noobie question about the Nord MM and midi |
| R_Gol wrote: |
when the editor window is open no audio is coming through. |
first
And then this is not supposed to happen. Can you try to plug headphones into the audio out of the MM to see if the same happens on those? (assuming the MM has a phones out like its big brother has)
I'll leve the other uestions for others  _________________ Jan
R_Gol
Posted: Thu Oct 17, 2019 10:45 pm Post subject:
| Blue Hell wrote: | | R_Gol wrote: |
first
I'll leve the other uestions for others  |
The problem solved. Now I can hear sound both with editor window open and not open.
The usb midi controller issue still on  |
