ld
Posted: Sun Sep 27, 2020 7:26 am Post subject:
AS3320 VCF Subject description: Schematic review and questions about Freq. Ctrl and Resonance Ctrl. |
Hello,
I am trying to breadboard a AS3320 VCF, and I have so far got to the point where I can hear music playing through the input and out the output. I also have been able to hear a basic sweep sound as I adjust the freq. ctrl. However, I haven't been able to get the resonance control to work, and the frequency control is quite noisy on one end of the spectrum.
My first question whether the input a CV control meaning it should be a difference in voltage across the pin? Or is it a current control, and I need some sort of vactrol to control it?
Here is my schematic so far attached. You can see the part I have in question is the pots. I also understand that the voltages should be -18 to +2 on the resonance ctrl. and +/-6V on the freq. ctrl. Can I achieve that by using a simple voltage divider? I tried making a voltage divider across the +/-12V, but even using equal value resistors, I couldn't get it to be +/-6V. It seems like the circuit itself is causing a load on the voltage divider which is messing up the values.
Any help on improving my schematic is appreciated. In particular, I would like to have pots that control the freq. ctrl. and resonance ctrl., as well as having a CV input. How do I combine the pot input and the CV input?
Thanks in advance for any help.
The schematic is here: https://imgur.com/a/M5XaRtv
(The forum wouldn't let me make an attachment? Is that because I am a new account?) |
Joined: Apr 03, 2004 Posts: 24509 Location: The Netherlands, Enschede
Posted: Sun Sep 27, 2020 8:11 am Post subject:
Re: AS3320 VCF Subject description: Schematic review and questions about Freq. Ctrl and Resonance Ctrl. |
| ld wrote: | | (The forum wouldn't let me make an attachment? Is that because I am a new account?) |
You should be allowed to attach files. What is the file extension? Maybe it is not an allowed file type. If so, I will (probably) change that. Otoh, it would be best to post schematics as an image or as a PDF, so that people without special software can view them too. _________________ Jan
ld
dslamnig
Joined: Dec 18, 2020 Posts: 28 Location: Zagreb, Croatia
Audio files: 6
