How to get "straight" note values only on LFO clock ?
Page 1 of 1 [3 Posts]
chapelier fou
PostPosted: Wed Nov 18, 2020 7:37 am    Post subject: How to get "straight" note values only on LFO clock ? Reply with quote  Mark this post and the followings unread
Simple problem. I want to avoid triplets and doted notes when modulating the rate of an LFO B used as a clock (slaved).
So I took notes of the correct values (0 8 16 24 32 40 48 60 72 84 96 108 and 120), put them in a SeqCtr (Unipolar output) and send them to the rate of the LFO.
But I can't get to get the correct result.
Any help ?
chapelier fou
PostPosted: Wed Nov 18, 2020 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
In fact, when set to clock mode, modulating the rate seems to put it out of the clock mode ?
Am I right ?
chapelier fou
PostPosted: Thu Nov 19, 2020 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
For your information I came out with these results :
Assuming that you put the LFO rate to 1/2 (72)
Unipolar values going into the Rate input (using a SeqCtrl to step through the list of values).
0 : 1/2
12 : 1/4
24 : 1/8
36 : 1/16
48 : 1/32
