NuttyMonk
Posted: Mon May 03, 2021 9:42 am Post subject:
LM358 not working as expected |
Hi all,
i am trying to use the LM358 as a comparator using a 5V single-sided supply and i expected to get 5V out on the upper part of the comparison but i'm only get about 3.8V. The reason i got them was due to a suggestion here on EM. I expected them to be able to go up to the supply rail voltage but that isn't happening.
Can anyone advise on an opamp which will do what i want?
When u search on a local electronics supplier
https://uk.rs-online.com/
one of the stats that you can search with in their opamps section is "Rail-To-Rail", yes or no. Is this the stat i should be paying attention to when looking for an opamp to go to the full rail voltage for comparators?
NM |
dk
Posted: Thu May 06, 2021 11:38 pm Post subject:
If you won't be using the chip for anything else, why not use a comparator chip? Something in the LM339 family perhaps? _________________ Horrors Of Dial-Up! on Facebook
Horrors Of Dial-Up! on Instagram |
NuttyMonk
Posted: Fri May 07, 2021 7:20 am Post subject:
Yeah, i've been looking at comparators since i posted this. They seem simple enough to use. I've ordered some LM311's to try out since i see them a lot on schematics.
Thanks
NM |
Posted: Fri May 07, 2021 9:13 am Post subject:
Re: LM358 not working as expected |
In this case a comparator would indeed be useful, or you could place a logic gate after the opamp if you happen to have an unused one in the circuit.
NuttyMonk wrote: | i am trying to use the LM358 as a comparator using a 5V single-sided supply and i expected to get 5V out on the upper part of the comparison but i'm only get about 3.8V. The reason i got them was due to a suggestion here on EM. I expected them to be able to go up to the supply rail voltage but that isn't happening. |
LM358 is useful for single supplies as its output can get pretty close to 0V but as you already found out it doesn't go up to the positive rail.
Fo that you would indeed need a rail-to-rail amp though those don't always work perfect either. Something like a CA3140 could work
but there are probably better options available. _________________ "My perf, it's full of holes!"
