Looking for identifying info on Eurorack phaser module
Page 1 of 1 [2 Posts]
Mark Hammer
PostPosted: Tue Aug 03, 2021 2:10 pm    Post subject: Looking for identifying info on Eurorack phaser module Reply with quote  Mark this post and the followings unread
I bought a used 4-stage VC-phaser module today, built around an AS3320 filter chip. The store couldn't really tell me anything about it. It is obviously built from a kit, given the soldering job and the legended PCBs.
I was wondering if it rang a bell for anyone, that might let me track down more info about it.
The unit is 6HP wide, has a green faceplate with three pots for FM, Q, and "FRQ" (I assume this is offset) and "PHASR" printed at the top. Four 3.5mm jacks are provided for audio in/out, CV in, and one labelled APF (I'm assuming a direct out for the wet signal).
I've done a thorough Google image search and nothing like this comes up. Any pointers or suggestions anyone can provide are deeply appreciated.
Steveg
PostPosted: Wed Aug 04, 2021 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mark,
Quite often front plates of DIY kits are not part of the kit. You might get results by posting a photo of the circuit boars showing any markings.
