 Forum index » Instruments and Equipment » Waldorf
Microwave PCB tour & service test routine demo
Page 1 of 1 [2 Posts]
abovenyquist
PostPosted: Wed Aug 11, 2021 12:13 pm    Post subject: Microwave PCB tour & service test routine demo Reply with quote  Mark this post and the followings unread
While I had the hood off to change the battery, I figured I'd take peek at the PCB. I also discovered that the Waldorf Microwave will refuse to receive MIDI (the MIDI light doesn't even come on) if it's set to a "corrupted" patch, i.e. what all the patches are apparently set to after you run the service memory check routines.
https://youtu.be/Hdv3byHIOco
Audio files: 228
PostPosted: Wed Aug 11, 2021 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats on the fix. You read your manual - amazing. Very Happy
