 Forum index » DIY Hardware and Software » The Repair Shop
What do you use to keep your SMD parts straight
cslammy
PostPosted: Wed Oct 13, 2021 10:54 am    Post subject: What do you use to keep your SMD parts straight
Subject description: Need to get the right storage and tools....
I have been doing more fab and repair work with SMD.
This is done by hand, with a soldering iron and hot air gun. No robotics etc., this is DIY
It's going O but I need a practical means to stage SMD parts while I'm building.
I see some users on Youtube using a sort of rotary thingy--like a lazy susan-- with different wedges where they put their parts. They then reach in and tweezer out whatever they need. OK, but I am not sure what this is called or where to get it.
I'd like this to be resistant to being bumped (so, you bump the staged SMD bin a bit and the parts don't all get scrambled). Extra credit if there is some easy way to label what each mini bin or wedgey or cutout or whatever has in it, because it can be really hard to read that directly off the SMD part if it's really small.
Any suggestions are appreciated. thanks.
