New Years Eve Concert
Page 2 of 3 [53 Posts]
shanemorris
Audio files: 92
PostPosted: Mon Dec 27, 2021 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and can stream Shane too if wanted.
thanks Jan!
ElectroCasa
Audio files: 297
PostPosted: Mon Dec 27, 2021 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jan!
Beam it up Shany! Laughing
Audio files: 297
PostPosted: Mon Dec 27, 2021 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool lovely - it makes me smile - nice poster!
PostPosted: Mon Dec 27, 2021 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy glad you like it
Audio files: 278
PostPosted: Mon Dec 27, 2021 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can stream Shane's set if that's easiest
Audio files: 297
PostPosted: Thu Dec 30, 2021 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm all set up for streaming the recording Shane sent me - it will be streamed on Shane's port - 8074.
Edit: updated the schedule for that.
shanemorris
Audio files: 92
PostPosted: Thu Dec 30, 2021 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jez and Jan!!
ElectroCasa
Audio files: 225
PostPosted: Thu Dec 30, 2021 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking forward to this. The poster and banner look fabulous...
PostPosted: Thu Dec 30, 2021 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wrote:
My plan is to interact with the equipment via knobs, switches, (etc.) with minimal keyboard input:
. Modular synthesizer
. Elektron Octatrack MKII
. Kurzweil K2600
This week has been quite an experience here in the studio. I have done a lot of troubleshooting, soldering, yet the issues have gone on without end. However, I am determined not to cancel again and so, well -- I am pressing on.
Well, I won't be using the Elektron this time -- I discovered that while I've used it in the past, I have gotten "rusty" with it and I am back on the Octatrack's notorious learning curve.
I wanted to do some clocked work however my Looperlative mysteriously stopped sending the MIDI reset command (from which I sync up my sequencers and clock dividers). Well, Bob Amstadt came to the rescue with a software update however the way the MIDI start command works now is different from how it used to work and I'm not ready to perform with it.
In the meantime, I keep running into little nits -- scratchy pots, etc ... and at one point I just laid on the couch (exhausted) for over an hour today.
While I have approached ambient music in the past, my plan is to do something very meditative and ambient this time. I will utilize the K2600 and the modular synth and think I can keep things simple enough that I won't fall on my face.
I am looking forward to tomorrow however will likely be getting last minute things in place right up to the performance time.
djfoxyfox
PostPosted: Fri Dec 31, 2021 6:43 am    Post subject: Event Listing
Subject description: SHARE IT!
I created an event listing at:
https://www.facebook.com/events/329897812120381
If you're on Facebook, invite people and share the listing.
Audio files: 278
PostPosted: Fri Dec 31, 2021 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
My setup
NYE setup 1
 Filesize:  333.01 KB
 Viewed:  187 Time(s)
shanemorris
Audio files: 92
PostPosted: Fri Dec 31, 2021 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
My set for NYE
Big thanks to Phobos, Jan, Jez and all the stream ops!
Link to the video of my set https://youtu.be/C0rJ8Gg-oio
shane_morris__electro_music_nye_2021_157.mp3
 Filename:  shane_morris__electro_music_nye_2021_157.mp3
 Filesize:  70.66 MB
 Downloaded:  538 Time(s)
ElectroCasa
shanemorris
Audio files: 92
PostPosted: Fri Dec 31, 2021 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pic from my set
 Filesize:  1.47 MB
 Viewed:  166 Time(s)
ElectroCasa
klangumsetzer
Audio files: 36
PostPosted: Fri Dec 31, 2021 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Again, thank you for organizing, creating a beautiful banner, testing, switching and your motivating comments: It was a pleasure to listen and perform!
This time I used the Morphagene module from Make Noise to improvise on a recording of me reading the poem "When Stars Are in the Quiet Skies" by Edward Bulwer-Lytton.
Happy New Year 2022!
2021 new year's eve set_klangumsetzer.mp3
(C)2021 by klangumsetzer
 Filename:  2021 new year's eve set_klangumsetzer.mp3
 Filesize:  54.34 MB
 Downloaded:  414 Time(s)
Make a joyful noise!
Eike
PostPosted: Fri Dec 31, 2021 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the recording of my set as I intended it to be heard.
It turns that while I included my looper's output on my monitor, I inadvertantly did not include it on the stream. In other words, what you heard was my playing WITHOUT the looper. There were a number of really thin sections that would have been covered by the looped material.
Fortunately, I hadn't changed my looper's settings and was able to add the looper track to the original and mix it for you.
Well, if you liked what you heard on the stream you will probably like this mix better.
Thank you for the opportunity to participate and to the stream operators, performers, and listeners for making this a rewarding event.
NYE_Dec_31_2021.mp3
Improvisation for New Years Eve Dec 31 2021
 Filename:  NYE_Dec_31_2021.mp3
 Filesize:  137.18 MB
 Downloaded:  491 Time(s)
PostPosted: Sat Jan 01, 2022 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to all involved in setting up and switching tasks and performing Smile
Had a nice day listening in to the event.
Here is my Epicyclus set using the blue modular and orange bass synth / waldorf pulse v1 / Nord G1 / Oberh matrix6R /Korg X5 / Jackson axe Very Happy
Epicyclus NYE 21 into 22.mp3
 Filename:  Epicyclus NYE 21 into 22.mp3
 Filesize:  42.1 MB
 Downloaded:  364 Time(s)
Audio files: 297
PostPosted: Sat Jan 01, 2022 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
And my set ... removed a couple of loud firework bangs (had the mic open at certain times), and shortened the intro a bit to make it last about 1 hour.
This was made with a couple of Wren patches - and the microphone was on for a bit of fireworks at the start and end.
2022-01-01--Blue Hell--2021 NYE, sponges.mp3
Blue Hell - 2021 NYE, Sponges
 Filename:  2022-01-01--Blue Hell--2021 NYE, sponges.mp3
 Filesize:  56.12 MB
 Downloaded:  445 Time(s)
Audio files: 297
PostPosted: Sat Jan 01, 2022 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice set Kevin!
Audio files: 495
PostPosted: Sat Jan 01, 2022 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks to all who parttook and contributed - great event as always. Smile
Edit: changed error in title
Muied Lumens - the 8760th hour.mp3
 Filename:  Muied Lumens - the 8760th hour.mp3
 Filesize:  54.85 MB
 Downloaded:  383 Time(s)
EscapeVelocity
PostPosted: Sat Jan 01, 2022 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my set for NYE 2021. I had a few streaming issues with butt dropping the connection and I had to restart that a few times. When I restarted butt I don't think it was recording on the main left/right channels out from my mixer so the recording made by butt did not included a lot of the other instruments played. Thankfully I was simulcasting to Twitch and that recording had everything recorded. So this is from the Twitch recording. There is a video of the set up on my you tube channel as well. https://youtu.be/q5zGNy-6c7I
Thanks to all stream ops and testers, Jan, robsol, and Phobos for helping me.
Escape Velocity live EM Radio New Years Eve 2021.mp3
 Filename:  Escape Velocity live EM Radio New Years Eve 2021.mp3
 Filesize:  66.44 MB
 Downloaded:  456 Time(s)
PostPosted: Sun Jan 02, 2022 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice track, Jan. And amazing that you did it all with a couple of Wren patches!
While listening it sounded like you had a battery of samplers, sequencers, and synthesizers.
djfoxyfox
PostPosted: Sun Jan 02, 2022 2:55 pm    Post subject: Missing Twyndyllyngs
Subject description: Did You Record Our Set?
Howard forgot to press record. If anyone recorded our set from NYE, please send me and/or Howard a copy. Thanks!
electro-nyc
PostPosted: Sun Jan 02, 2022 6:14 pm    Post subject: redgreenblue set Reply with quote  Mark this post and the followings unread
Here is my set from the show. it was nice to perform again after 2 years of no live shows. This is a preview of what will eventually be my next album 'blue'.
NYE 2021 -blue (early version) redgreenblue.mp3
redgreenblue - blue-ish (early version)
 Filename:  NYE 2021 -blue (early version) redgreenblue.mp3
 Filesize:  34.87 MB
 Downloaded:  434 Time(s)
Audio files: 278
PostPosted: Tue Jan 04, 2022 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my set on Twitch
https://www.twitch.tv/videos/1248920199
enjoyed kevin's updated set and both of jan and rob's posted sets too Smile
Audio files: 297
PostPosted: Tue Jan 04, 2022 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kevin and Jez Smile
