March Equinox Live streaming event
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
Audio files: 161
PostPosted: Thu Mar 31, 2022 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Had a great day listening in to the music on the spring equinox Smile
Thanks to all the participants and technical staff on the day Smile
Here is the Epicyclus set from the event day , the first section used the modular set up with 4 step sequencers clocked from a diy master clocking module.
Each sequencer ran it's own simple mono synth patch and using the almost finished CGS-60 quad FX pedal/modular level converters (thanks Alan Smile ) to add some delay / verb pedals to the sequences , i also tapped off a sequencer clock into the juno-60 to lock an arppegio to the modular timing, the hexinverter diy jupiter storm came out again for strange high freq modulation noises through a cv controlled auto-pan mfos module.
The last section of the set used the RM1X midi sequencing / diy drum synth / diy Ambika / Waldorf pulse v1 / modal argon 8M / B - td3.
Dave Smile
Epicyclus spring equinox march 2022-001.mp3
 Filename:  Epicyclus spring equinox march 2022-001.mp3
 Filesize:  42.13 MB
 Downloaded:  574 Time(s)
Audio files: 512
PostPosted: Thu Mar 31, 2022 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant set Dave! Cool
PostPosted: Wed Apr 27, 2022 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Once again, I had nothing to offer sound-wise (I read this forum almost daily but haven't built or played with electronic sound-making devices in a long time).
I couldn't listen live either, but I've listened to all the posted recordings and enjoyed them all. Thank you to ALL involved.
BlueHell: Hmmm, yeah, maybe it gets too messy Smile.
kkissinger: This is a great piece!
.: james :.
PostPosted: Wed Apr 27, 2022 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
But you survived Laughing
But it was messy .. I'll try to make things simpler .. if I don't forget .. or get carried away again Wink
Around june 21 probably - hope to hear you too then Cool
