Increment sequencer each key trig
Page 1 of 1 [5 Posts]
Oortone
PostPosted: Sat Sep 10, 2022 1:16 pm    Post subject: Increment sequencer each key trig
Subject description: Common increment for all voices
Hello.
I want to increment the sequencer for each key pressed in a polyphonic patch and I want it incremented for all voices each time. Somewhat similar to the "mono" option in LFO:s.
I know I can put the sequencer in the FX-area and use the BUS send to send a common logic signal to all voices but I'm out of buses. Is there a workaround for this using only the polyphonic VA (Voice Area)?
It "feels" like it could be but I can't figure it out right now.The closest I get is to use Control Sequencer and voice number but then the sequencer order gets broken since voice assignments are semi random.
PostPosted: Sat Sep 10, 2022 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. I'm getting a bit rusty on it .. but .. internal MIDI maybe?
Oortone
PostPosted: Sat Sep 10, 2022 3:42 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Oh yes indeed!
Thanks a lot for that idea.
Sequencer in FX area sending midi CC#13 to the Slot
Assigning CC#13 to a Constant module in the Voice Area of that slot to receive.
Perfect.
PostPosted: Sun Sep 11, 2022 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Oortone
PostPosted: Sun Sep 11, 2022 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
And here's another way to do it without involving FX-area. However it will not advance the sequencer if the same key is triggered repeatedly.
 Filesize:  58.5 KB
 Viewed:  2432 Time(s)
