 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
G2 Metronome
Page 1 of 1 [4 Posts]
Calude Voiot
G2 patch files: 5
PostPosted: Sat Aug 06, 2005 10:26 am    Post subject: G2 Metronome Reply with quote  Mark this post and the followings unread
A clumsy G2 emulation of the BOSS Dr.Beat 66 metronome (did let the tap tempo out though ) I hope this can be useful for somebody!! it was a good patching lesson for me anyway.
feel free to show me this can be made with less half the modules Wink
Calude
metronome_cv.pch2
a BOSS Dr.Beat 66 metronome emulation
 Filename:  metronome_cv.pch2
 Filesize:  3.43 KB
 Downloaded:  1691 Time(s)
Audio files: 309
PostPosted: Sat Aug 06, 2005 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe also have a look at : http://electro-music.com/forum/topic-3292.html&highlight=tap+tempo where Fozzie posted a tap tempo patch (that everyone downloaded but noone responded to :shock: )
Jan.
Calude Voiot
G2 patch files: 5
PostPosted: Sat Aug 06, 2005 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jan
I saw this patch but its not worth the hassle , it will not work on the demo because it sends itself a midi cc (cc20=tempo) and as clumsy as my patch is it already uses too much Memory to add another 73 % ....
may be Clavia will add the tap tempo one day ...
Calude
Audio files: 309
PostPosted: Sat Aug 06, 2005 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe something like this can help you reduce DSP resources ?
Using modules with many outputs is pretty expensive (DSP wise), and using a generator for each click as well. So I tried to find something using less of both.
I know about nothing when it comes to counting in music, but it seems to me this aproach can count in a lot of ways.
As an alternative for the accents section you could use a sequencer, it probably is a bit cheaper and it will allow you to count to 16 instead of 8.
And for some reason the thing wont count to 2, there's always something with counters & Clavia & me.
Anyway, just an idea.
Jan.
metro.prf2
a cheaper metro, not the cheapest I still I guess
 Filename:  metro.prf2
 Filesize:  3.96 KB
 Downloaded:  2888 Time(s)
