6CS7 tubes for analogue to digital sampling project
kasperbergholt
PostPosted: Sat May 06, 2023 8:02 am    Post subject:  6CS7 tubes for analogue to digital sampling project Reply with quote  Mark this post and the followings unread
Hello Electro Music forum,
I'm on the lookout for some 6CS7 tubes for a sampling project based on a high-end pickup and a Leben CS-600 (for extracting samples from a number of old records through a Leben RS30-EQ built around two ECC81 tubes & one 6X5T rectifier tube, all of which are New Old Stock.
The aim is to mirror signal processing (amplification) as it was done 50 to 70 years ago, whilst retaining a very high level of quality and low noise levels.
Inspirations are some of the early Motown Recordings and releases from American label Cadet Records, e.g. Dorothy Ashby's Afro-Harping from 1968.
I'm currently using a cheap Motu soundcard, but will upgrade if results are good, which I suppose they will be.
But I'm running low on this type of tubes and thought someone here might have some for sale - even if it's a longshot.
Thanks in advance,
Kasper
