1 pole 8 position rotary switch interchangeable?
Page 1 of 1 [3 Posts]
glnds
PostPosted: Tue Jun 11, 2024 10:15 am    Post subject: 1 pole 8 position rotary switch interchangeable?
Subject description: Help to interprete a datasheet
For their VCO340, Doboz refers to SRBV181004 for its 1 pole 8 position rotary switch.
I have a similar one, but I'm not sure if it's interchangeable. All specs look more or less the same: SR1712F-0108-20F0A-N9-N-027
The main difference I can see is that the Alpha one is missing a "C" indication at Pin 10 (not sure what this means and how important that is)
Any advice?
Thanks,
Gert
PostPosted: Tue Jun 11, 2024 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
C is the common contact and that;s for both pin 1 and 10 for both switches ... and it looks like that when you want 8 positions you connect common to both 1 and 10 - at least such will not hurt ...
To me they are compatible.
glnds
PostPosted: Tue Jun 11, 2024 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the clarification Jan!
