Applying envelope to RP2040 PWM output
Page 1 of 1 [2 Posts]
Mickeyluv
PostPosted: Mon Mar 24, 2025 9:40 am    Post subject: Applying envelope to RP2040 PWM output Reply with quote  Mark this post and the followings unread
I want to apply a simple AR envelope to the PWM output of the Hagiwo chord VCO V2. My thought is to use a variable 'envelope_level' which is an integer value (say, 0-511) that follows the attack and decay cycles.
Presumably the output levels are set by, for example;
pwm_set_chan_level(slice_num, PWM_CHAN_A, wavetable[(int)osc_progress[0]]/4+wavetable[(int)osc_progress[1]]/4+wavetable[(int)osc_progress[3]]/4+511);
How should the envelope be applied so that the output ranges from silent through to the original level?
I'm thinking that envelope_level could be normalised in the range 0 to 1 and used to multiply
wavetable[(int)osc_progress[0]]/4+wavetable[(int)osc_progress[1]]/4+wavetable[(int)osc_progress[3]]/4 before adding the 511 offset. Is this correct?
RP2040 Chord VCO V2.ino.txt
 Filename:  RP2040 Chord VCO V2.ino.txt
 Filesize:  25.15 KB
 Downloaded:  122 Time(s)
Mickeyluv
PostPosted: Tue Mar 25, 2025 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Just done some experimenting and found that multiplying by envelope_level then dividing by 511 before adding 511 works fine.
