 Forum index » How-tos
Building A Sampler-type device
Page 1 of 1 [11 Posts]
Scott013
PostPosted: Tue Aug 16, 2005 11:58 am    Post subject: Building A Sampler-type device Reply with quote  Mark this post and the followings unread
Ok, I play guitar mostly, but I am very interested in electronics and electronic music. I have a a tiny bit of experience with circuits (I built a square wave oscillator). I want to build something that I can record several sounds onto, and then push a button for the sound (or possibly beat) to play back. I don't want to record anything major, just some ambient noise or perhaps a loop of a short beat. It would be really nice if I could store sound on some sort of removable media (flash memory?), but that's not neccesairy.
I'm having a tough time finding information on recording/playback of sounds, so can anyone here either point me towards some information, or give me some directly?
PostPosted: Tue Aug 16, 2005 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohh, this is a pretty big DIY project, really. There are chips out there that can record (radio shack sells a kit like this for ~$20), and would simplify things for you greatly. But it is primarily an analog circuit, with a analog storage device, if I remember correctly. It might have been updated to be digital, but it's still an all-in-one chip with no external storage.
Going digital, however, you need to spend time with an ADC, probably a microcontroller, and DACs. For simple things, you can try looking at http://www.atmel.com. Look for the AVR 8-bit microcontrollers, then look for the appnotes. There is a sound recorder application, records 8-bit @ 11kHz I think. In the appnote is code & schematic. Made for voice-recorder type things, but you can always add features in software (like triggering & beat detect), once you have the thing running. WinAVR is the free toolset for that processor, look at http://www.avrfreaks.com for more info & downloading.
jkn
PostPosted: Tue Aug 16, 2005 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not a diy person at all - but I noticed a few things in researching modular synths that might apply to what you're thinking of... This would be more along the lines of building a pedal or similar...
Ken Stone's Delay Development Board - schematics, etc...
http://www.cgs.synth.net/modules/cgs44_ddb.html
Here's the rest of his designs - http://www.cgs.synth.net/
You also might try doing some searches at http://www.synthdiy.com/
PostPosted: Tue Aug 16, 2005 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.nescivi.de/research/sampler/sampler.html
Nescivi is a member here and might be willing to answer any and all questions if you ask nicely.
dnny
PostPosted: Wed Aug 17, 2005 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
this sounds like interesting project.
there is lots of information and one schematic to make a simple sampler (16 -20 sec record)
on the ISD1400-series Datasheet
you can head sound sample from Bugbrand´s devices page scroll down for dirty sampler Smile
daniel
www.koelse.org
flickr: cable porn group
Scott013
PostPosted: Wed Aug 17, 2005 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all the info guys, I'll start looking into it all now.
PostPosted: Thu Aug 18, 2005 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Nescivi occasionally gives workshops on that little cerquit as a introduction into synth DIY. I could be that she has one of her little bags with a print of that text and the parts left over.
Just speculating there but it can't hurt to try....
opg
PostPosted: Thu Aug 18, 2005 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you want a Roland MS-1. I won one on eBay for $35, but the guy never picked up the money. Oh well. The MS-1 uses Compact Flash cards and also has RCA or 1/8" inputs to import your sounds, and 8 buttons to trigger sounds (with 3 banks of sounds). It seemed perfect, but I haven't seen any MS-1s on eBay in a while.
I am also having a frind build me a drum module that has 6 drum trigger inputs and plays 8-bit sounds that, hopefully, will be loaded via USB in the end. It is not finished yet, but he will put all the plans on the site: http://27b-6.lathan.org
There are occasional updates and a few pictures of the progress right now. All you would have to do is change the trigger inputs to push-buttons. Of course, it is set up for 8-bit 22050 Hz sounds, but I think you can change that with a faster DAC. It's not really a beginner project, but at least you could have all the info for it.
Scott013
PostPosted: Thu Aug 18, 2005 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
That Roland MS-1 sounds great, I should probably just buy a sampler. I would rather spend my time making sound instead of the sampler that will play the sound I think. This sampler is starting to look like a fair bit of work.
That project looks interesting though, I will look into it.
PostPosted: Thu Aug 18, 2005 3:41 pm    Post subject: Re: Building A Sampler-type device Reply with quote  Mark this post and the followings unread
Woah!! hold your horses!!!!!!!!!!!!!!!!
Isn't this like trying to drive a car before you've been given birth to????
That playback chip looks fun (it could be circuit bent too?)-
I'd also recommend looking at a Yamaha SU10- as the ribbon controller on it enables you to 'scratch' the sample- which is great for stroking really slowly and getting an almost granular sound from it
Howabout just building RW's SoundLab to start and do a simple sampler when you've got some more construction experience?
Tom
PostPosted: Thu Aug 18, 2005 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's one way of looking at samplers. You can also look at them as enabeling you to intergrate acoustical sounds with electronic ones. Don't forget that the sound your sampler plays can also be made by you....
