nerd of nerds
Posted: Fri Aug 26, 2005 3:33 am Post subject:
Any super simple CV keyboard schematics? |
Hi!
I'm in the planning stages of my soundlab right now. I'd like to give my SL a small 1 or 2 octave flat keyboard (like the super spiffy one in the gallery) but i don't exactly know how
this will be my first analog synthesizer ever...  |
Joined: Jan 31, 2003 Posts: 18240 Location: Durham, NC
Audio files: 224
Posted: Fri Aug 26, 2005 6:02 am Post subject:
to electro-music.com, nerdy. Good to have you here.
No need to be embarassed about not know exactly what to do. There are many solutions, and don't rule out using a MIDI keyboard with a MIDI/CV converter. Also, consider just starting on the Sound Lab and rig up a simple performance interface with just a pot and a switch. _________________ --Howard
my music and other stuff |
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Fri Aug 26, 2005 11:05 am Post subject:
Re: Any super simple CV keyboard schematics? |
nerd of nerds wrote: | Hi!
welcome nerd
the spiffy one that is on the gallery is this one - just scroll to the bottom of the page and you will find how to make a One Octave Stylys Keypad.
dnny _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
nerd of nerds
Posted: Fri Aug 26, 2005 11:15 am Post subject:
mosc wrote: | to electro-music.com, nerdy. Good to have you here.
No need to be embarassed about not know exactly what to do. There are many solutions, and don't rule out using a MIDI keyboard with a MIDI/CV converter. Also, consider just starting on the Sound Lab and rig up a simple performance interface with just a pot and a switch. |
the reason i don't wanna use midi is because i want to make this thing as small as possible...
could i do midi as well as the knob-button interface?
And could you explain to me what exactly CV, Gate , and trigger is?
like i said, this is my first analog synth, i've been using digi synths for a while now and wanted to move into the realm of analog/diy... |
Audio files: 224
Posted: Fri Aug 26, 2005 1:51 pm Post subject:
CV -> control voltage. These are used to control oscillators, filters and other anlog modules.
Triggers -> signals that turn on/off modules, like envelope generators.
These are the two types of controls analog modular synths generally use.
MIDI is a digital interface that can be converted to CV and Trigger with an special device. The nice thing about MIDI is tha most modern synths generate it, as do computers. You can also buy neat low=cost MIDI keyboards and knob boxes. _________________ --Howard
nerd of nerds
Posted: Fri Aug 26, 2005 3:12 pm Post subject:
mosc wrote: | CV -> control voltage. These are used to control oscillators, filters and other anlog modules.
MIDI is a digital interface that can be converted to CV and Trigger with an special device. The nice thing about MIDI is tha most modern synths generate it, as do computers. You can also buy neat low=cost MIDI keyboards and knob boxes. |
yeah, i know and love midi, so far my setup consists of a roland sh-32, roland mc-307, and a korg microkontrol...
Is there any way of syncing a diy analog step sequencer with the rest of my gear? preferably cheaply
oh, and thanks for the warm welcome! |
Audio files: 224
Posted: Fri Aug 26, 2005 4:30 pm Post subject:
Well, if you build or buy a MIDI to CV converter, you will be in business. I'm sure if you look there are DIY solution. I bought one years ago. I know Deopfer makes these - others I'm sure. _________________ --Howard
SuperKoopa
Posted: Mon Sep 19, 2005 3:22 pm Post subject:
All my respect to Mr. Wilson but this:
http://www.cgs.synth.net/tube/controller.html
Is simpliest than the single bus keyboard !
the question is :could be this scaled for 1V/Oct?
Please can anybody answer me? |
SuperKoopa
Posted: Sat Oct 08, 2005 6:51 am Post subject:
hi! i've tested this circuit with circuit maker software and it seems to work but i think that there's a problem. when a key is pulled down cv voltage goes to desired level (es. 83 mV) but when the key is relased cv goes to the highest level (if you use a 9V supply this level is 7V!). so probably if you play a patch with long decay in VCA the pitch doesn't stay at the previous level when you relase the key.Is this true?
i'm not an expert in cv voltages,i haven't built my SL and i'm still on planning!
what this project needs for fix this problem?
please answer me soon! |
Posted: Sun Oct 09, 2005 1:38 am Post subject:
Yeah, I think you're right. As the note faded out (VCA) the pitch would rise.
Also I'm uncertain if it will put out 1V/Oct as the text talks about 2 1/2 octaves from a few millivolts to V+(12V). This doesn't add up.
I'm not sure how you would fix this. Still it looks worth experimenting with. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Oct 09, 2005 1:52 am Post subject:
Hey Nerd of nerds,
Good to have you on the forum.
For heaps of questions which will come up as you build your SL, check all over Ray's sight. There are alot of things there, but you have to search around.
If you want a truly tiny keyboard investigate mounting tactile switches onto a piece of stripboard. (You'll find that Uncle Krunkus always reaches for the stripboard first ) This is something I'd like to try out soon, when I get around to it. They come in black and white (and lots of other colours!) and can be arranged on the board however you like. Then decide decoded matrix or single bus and wire appropriately.
Also, there's a circuit here,
http://www.hoohahrecords.com/resfreq/modular/patseq/patseq.html
It uses a PIC which is pre-programmed to give the classic 5pin sync signal from a midi input. (The PIC costs about AU$20) This circuit is one I definately want to try when I get a few other things out of the way.
Happy building,
(don't plan too long, get that soldering iron warmed up now!!)
See ya,
Andrew _________________ What makes a space ours, is what we put there, and what we do there. |
senkun
Posted: Thu Feb 26, 2009 1:44 pm Post subject:
Hey guys,
Sorry to dig up this way old thread. I thought I should just add on to here rather than start another.
As in my other question about cheap simple controllers for a Soundlab, I'm getting fixated on using a ribbon controller (since it's relatively affordable with the Softpots). The other technical threads on ribbons got me all overwhelmed.
So searching high and low I found this thread and I got really hopeful when I read what mosc said;
mosc wrote: | .. consider just starting on the Sound Lab and rig up a simple performance interface with just a pot and a switch.. |
Unfortunately he didn't elaborate and all 2 of my brain cells are struggling to grasp what he meant when he said "rig up a simple performance interface with just a pot and a switch".
How do I rig that up to control my Soundlab? Where do I start?
I really hope that this can be done easily because instead of using just a standard pot, since the Softpot is a potentiometer, is it not possible to use it in this "simple performance interface "?
Pray enlighten a total dummkopf.  |
Posted: Thu Feb 26, 2009 2:12 pm Post subject:
Connect the "top" of the ribbon controller to your +9V supply
Connect the "bottom" to the -9V supply
Connect the "tap" to one of your CV ins,
and use the manual trigger to gate your envelope
That would be the simplist way.
There are much more elaborate ways of doing it, which you can read all about in Scott Stites's "Softpot Ribbon Controller" thread.
BTW a 100K pot hanging off each end of the ribbon controller (in series) will give you a more control over "where you're at" octave wise. _________________ What makes a space ours, is what we put there, and what we do there. |
senkun
Posted: Sat Feb 28, 2009 12:33 am Post subject:
Uncle Krunkus wrote: |
BTW a 100K pot hanging off each end of the ribbon controller (in series) will give you a more control over "where you're at" octave wise. |
Hey Uncle K,
I would assume "tap" means "wiper"?
And why a pot on each end? Can it be just one pot on the end that goes to +V
Posted: Sat Feb 28, 2009 1:07 am Post subject:
Just to help you "dial in" the octaves you want the softpot to cover.
If you only want one, it's better to put it on the -ve side. _________________ What makes a space ours, is what we put there, and what we do there. |
senkun
Posted: Sat Feb 28, 2009 1:16 am Post subject:
Actually, I could just connect the ribbon to these controllers right? (I hope)
Ray's Single Buss 1V/Oct or Mini-Controller.
If so, would these be the connections of ribbon to controller board?
"top" of the ribbon to controller board "KBTP"
"bottom" to the controller board "GND"
"tap" to the controller board "KBUS"
What do "GLA" and "TLA" on the controller board do? LED anodes to "GND"? |
Posted: Sat Feb 28, 2009 3:15 am Post subject:
I think so,
GLA and TLA aren't used on that board IIRC. _________________ What makes a space ours, is what we put there, and what we do there. |
