Cubase patchname script for G2 and gererating app.
BobTheDog
PostPosted: Sat Sep 17, 2005 3:13 am    Post subject: Cubase patchname script for G2 and gererating app. Reply with quote  Mark this post and the followings unread
Hi Everyone,
There are 3 zip files here for Cubase users.
Basically a script file for importing into Cubase so you can select by Patchname, works for all banks.
An application fo you to create scripts from the patchnames inside your own G2.
Source code for the app.
Andy
script.zip
This is the one to start with. Contains a script file for the factory 1.32 patches and also a readme which covers all 3 zips.
 Filename:  script.zip
 Filesize:  17.63 KB
 Downloaded:  459 Time(s)
G2ScriptGen.zip
Aplication (for pc) that will create a script file with the patchname from your own G2 (with a little work from you as well).
Please see readme.txt in Script.zip
 Filename:  G2ScriptGen.zip
 Filesize:  27.71 KB
 Downloaded:  417 Time(s)
G2ScriptGenSource.zip
The source code in C++ for any intrepid Mac user that wants to build it for macs.
 Filename:  G2ScriptGenSource.zip
 Filesize:  4.15 KB
 Downloaded:  332 Time(s)
