Streaming now
scales & the note quantizer module
Page 1 of 1 [5 Posts]
seawolf
PostPosted: Mon Sep 19, 2005 9:47 pm    Post subject: scales & the note quantizer module Reply with quote  Mark this post and the followings unread
Hello all. I am wondering if someone could give me a rundown on the note quantizer, because I am trying to figure out how to produce only the notes within certain scales. I have heard that the note quantizer might be good for this. I have also tried the key quantizer but am confused by the results... How can I use these modules to produce only certain notes within a patch?
My thanks for any advice.
-Elijah
Seawolf
http://www.teamabunai.org/seawolf/
razo
PostPosted: Wed Oct 26, 2005 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's simple. Just click on the keys in the module that is contained in your scale. Then use an LFO or whatever as the input.
Razo
Are we artists or technicians?
seawolf
PostPosted: Fri Nov 11, 2005 11:43 am    Post subject: thanks Reply with quote  Mark this post and the followings unread
my thanks razo.
It was a bit confusing at first because I was not getting the expected output,
but after some tinkering with LFO's and the Note Sequencer, I understand its use.
Cheers!
Seawolf
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Nov 11, 2005 5:09 pm    Post subject: Re: thanks Reply with quote  Mark this post and the followings unread
seawolf wrote:
my thanks razo.
Cheers!
The trick about the Key Quantizer module is remembering that the buttons are set up based on the key of "E". Notice the little <0> zero symbol below the "E" key. There are basically two ways to set up a scale - use the buttons to select the exact notes that you want, or use the buttons to select the scale you want based on the key of E (meaning do you want a major scale, minor scale, etc) and then tune the osc to the key you really want.
Dave Peck
and70it
PostPosted: Mon Nov 14, 2005 12:32 am    Post subject: scale trick Reply with quote  Mark this post and the followings unread
can you tell me if i have really understand?
the key quantizer work in E
if i want to set up a C minor scale,
i must set up a E minor scale
and than i make a transposition from
E to C?
