DIY Oscillator
Page 1 of 1 [6 Posts]
Axiom
G2 patch files: 28
PostPosted: Sat Nov 05, 2005 2:17 am    Post subject: DIY Oscillator Reply with quote  Mark this post and the followings unread
Here's my attempt to build an oscillating circuitry. I've used Clock generator, FlipFlop, Inverters and DA to generate an oscillation. A series of pitch shifters is used to boost osc's frequency. Changing p.s. delays will modify the shape of the waveform.
Feel free to improve this file Smile
Luca
DIY Osc.pch2
 Filename:  DIY Osc.pch2
 Filesize:  1.31 KB
 Downloaded:  1550 Time(s)
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Nov 05, 2005 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
This is an unusual design -but it works. Very Happy
For a more "usual" approach, you might want to check out this thread.
Axiom
G2 patch files: 28
PostPosted: Sat Nov 05, 2005 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx tim Smile I've checked yours and is very awesome.
Luca
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Nov 05, 2005 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
another one: env as osc
EnvOsc TK.pch2
envelope as oscillator...
 Filename:  EnvOsc TK.pch2
 Filesize:  938 Bytes
 Downloaded:  1540 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Nov 05, 2005 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
logic delay as oscillator...
LogicDelayOsc TK.pch2
does like it says or your money back
 Filename:  LogicDelayOsc TK.pch2
 Filesize:  899 Bytes
 Downloaded:  1661 Time(s)
Axiom
G2 patch files: 28
PostPosted: Sat Nov 05, 2005 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
eheeh but you even use an oscillator as start point Razz I don't know if, actually, there are a way to find some blocks that can act as resistors and capacitors.. if we can be able to build a Shmidt trigger we can begin to do some nice experimentitions Smile
Luca
