LM324-projects...
Page 1 of 2 [31 Posts]
Pehr
PostPosted: Fri Nov 25, 2005 8:37 am    Post subject: LM324-projects... Reply with quote  Mark this post and the followings unread
I've got ~125 LM324s and thought I'd build something of them. They're good since they run on both single and dual power supply, but the input voltage range is from -0.5V to 32V, not +/-15V as the TL084 Confused Is that a big disadvantage?
I know that the DS7 uses LM324, but I don't want 60 of those Razz
Is there any other good applications of the LM324?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Fri Nov 25, 2005 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good for sensors (piezo drum pads, photodiode light sensors, simple microphone circuits). Maybe build a new controller instrument?
danielwarner
PostPosted: Wed Nov 21, 2007 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Arthur Harrison's audio sweep oscillator uses a couple LM324s:
http://home.att.net/~theremin1/Circuit_Library/sweep.html
etaoin
PostPosted: Thu Nov 22, 2007 12:49 am    Post subject: Re: LM324-projects... Reply with quote  Mark this post and the followings unread
Klee!
http://www.casia.org/modular/
Pehr
PostPosted: Thu Nov 22, 2007 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I know! Very Happy
I could build abt 60 Klee sequencers with all the 324s I have Rolling Eyes Laughing
YouTube channel
flickr photostream
andrewF
PostPosted: Thu Nov 22, 2007 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
CGS39 quad logic gate uses two LM324s, you could build 60 of those.
CGS29 wave multipliers use three......40 ?
Pehr
PostPosted: Thu Nov 22, 2007 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, those logic gates looks interesting. I'll build some of these too Very Happy
the 324 is a good comparator I guess Rolling Eyes
YouTube channel
flickr photostream
Pehr
PostPosted: Thu Nov 22, 2007 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't know the wave multiplier used 3 though Very Happy Shocked
YouTube channel
flickr photostream
frijitz
Audio files: 54
PostPosted: Thu Nov 22, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Agree! I used them extensively for interfacing my wind controller to a pic:
http://home.comcast.net/~ijfritz/sos_circ.htm
Ian
Pehr
PostPosted: Thu Nov 22, 2007 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess I have to learn to play the clarinet then Razz
YouTube channel
flickr photostream
Pehr
PostPosted: Fri Nov 23, 2007 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps the Papareil VC-Dual Linear ADSR?
Marc Bareille wrote:
TL072 and LM324 aops...
Rolling Eyes
YouTube channel
flickr photostream
softfin
PostPosted: Fri Nov 23, 2007 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The 324 was (is still?) used on a lot of Electro-Harmonix effect pedals. I bought some of them years ago for a Small Clone chorus. Hehe, that one ended up being the most heavily modified project I've ever built . Very Happy
andrewF
PostPosted: Fri Nov 23, 2007 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Houshu`s HADSR only needs one chip - LM324
http://www5b.biglobe.ne.jp/~houshu/synth/eg0105.gif
mediatechnology
PostPosted: Sun Nov 25, 2007 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
That spec is actually for single-supply operation and it's a huge advantage. It doesn't apply, in the range stated, for dual supply operation. What it's saying, and a unique attribute of the part, is that the common mode range, in single supply, includes ground by virtue of PNP input devices. Vout also goes to ground and the 324 has very low supply current ideal for battery use.
The penalty is that the output runs essentially in class-B with large cross-over distortion and low slew rate.
One application for the LM324 you don't normally see is in bar-graph comparator strings. They're simply too slow to oscillate and thus make a fairly good driver. SSL used them in the 82E10 channel dynamics processor as a GR indicator.
http://www.ka-electronics.com/images/SSL/ssl_82E10.pdf
This part is over 30 years old and still a valuable workhorse.
frijitz
Audio files: 54
PostPosted: Sun Nov 25, 2007 9:44 am    Post subject: Re: LM324-projects... Reply with quote  Mark this post and the followings unread
I've used the 324 in the latest incarnation of my SNICster waveshaper:
http://home.comcast.net/~ijfritz/sy_cir10.htm
This new variation is a simplified version of the original without the extra waveshaping features. I used the 324 for the control and output sections (A3a, A4a, b, c). The slow slew rate removes most of a nasty switching glitch the occurs at the point where the input SAW switches.
Ian
Pehr
PostPosted: Sun Dec 02, 2007 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some Yusynth modules can use the LM324 Cool
http://yusynth.net/Modular/EN/MINMAX/index.html
http://yusynth.net/Modular/EN/WAVEFOLDER/index.html
YouTube channel
flickr photostream
Pehr
PostPosted: Mon Dec 10, 2007 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
How about the LM358? Confused Could the LM324 replace it?
Or are there important differences?
I know they're 8-pin and 14-pin, but one could change the PCB layout for that.
YouTube channel
flickr photostream
Clack
PostPosted: Mon Dec 10, 2007 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
national semiconductor says for the lm358 in the 'also recommended' box -
"LM324 Quad Version"
which means I guess its pretty much identical in characteristic
http://www.national.com/mpf/LM/LM358.html
Clacktronics.co.uk
Rykhaard
PostPosted: Mon Dec 10, 2007 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
FINALLY finished my Wave Multiplier from Ken Stone a couple of weeks ago. If you like twisting things around and you still have a lot of LM324's - buy some Wave Multipliers!! ShockedShockedShocked OMFG! That is one extremely impressive collection of modules that Ken cobbled together!! I'll be ordering at LEAST 1 more of them for twisting things around. Very Happy It has a nicely simple but nice and gritty at times distortion section as well. Wink
Also - if you wanted to offload some 324's and are a Paypal'er- lemme know! Wink I use them in a few things as well. Very Happy
Pehr
PostPosted: Mon Dec 10, 2007 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the answer guys Very Happy
This means I can use more of my 324s Cool . For example: cgs drum simulator, cgs analog xor/xnor, Yusynth audio/CV Mixer... Twisted Evil
Rykhaard: I think I'll build the Yusynth version of that multiplier. No 3080s there Smile
Btw, If I get any of my 324s left I'll let you know Wink
YouTube channel
flickr photostream
Pehr
PostPosted: Sat Dec 15, 2007 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
LM324 effects:
http://yusynth.net/archives/Elektor/Waveshapers-1980.pdf
http://yusynth.net/archives/Elektor/dent_de_scie_module.pdf
Now all I need to do is practice my French Very Happy Rolling Eyes
YouTube channel
flickr photostream
PostPosted: Sat Dec 15, 2007 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
there is a 0R resistor in the hold section. never seen something like that. what's about this zero ohm resistor?
Pehr
PostPosted: Sat Dec 15, 2007 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I have never understood that either... Confused Perhaps it's like a fuse?
http://en.wikipedia.org/wiki/Zero-ohm_resistor Question
YouTube channel
flickr photostream
andrewF
PostPosted: Sat Dec 15, 2007 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I assumed, as Houshu has `corrected dec01` next to it, he previously had a resistor there but decided it wasn`t necessary and it was easier to insert 0 R than redraw the schematic.
That was just my assumption, in fact you CAN buy 0 R resistors (why? I don`t know)
You can write to Houshu - he is a VERY nice guy (he once drove a return trip total of about 4 hours to pick me and my synths up, to go to a synth-diy meeting)
Pehr
PostPosted: Sat Dec 15, 2007 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
About zero ohm resistors:
Wikipedia wrote:
This format allows it to be placed on the circuit board using same automated equipment used to place other resistors instead of requiring a separate machine to install a jumper or other wire.
EDIT: http://www.micro-ohm.com/filmcarbon/jumper.html
YouTube channel
flickr photostream
