sequencer question
Page 1 of 1 [4 Posts]
and70it
PostPosted: Wed Dec 14, 2005 10:20 am    Post subject: sequencer question
Subject description: the clavia g2x note sequencer contol a sample soft in my computer
I use lisa ( a real time sampler from steim.org) and i need a trick to control some sample with the note seq of my g2x and the other lisa sample with the g2x keyboard.
For the sequencer i need the midi note and the relative duration (clk... 1/8, 1/16, 1/32 etc). Can i do this?
I play lisa with the g2x via keyboard very well, with a proper patch can i control different sample of lisa inthe same time with sequencer and with the keyboard?
thanx for help
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Dec 15, 2005 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pain in the butt. I usually use a clock divider which is Midi controlled by a level sequencer. I can post patch if helpful.
I will be in NAMM 06!
/Zsad
and70it
PostPosted: Fri Dec 16, 2005 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
yes this will be very helpful
thanx
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Dec 16, 2005 7:27 pm    Post subject:   Reply with quote  Mark this post and the followings unread
OK, here is the patch ... the demo is the kick drum in the fx area ... the clock divider is being modulated by the sequencer through midi out->in ...
the Voice area needs a synth to be copied in. and connected to gate output. I had to take mine out of this ptach. It was getting too special ...
It is playing right now ...
/Dasz
ClockGate_DZ.pch2
ClockedGate_DZ
 Filename:  ClockGate_DZ.pch2
 Filesize:  4.47 KB
 Downloaded:  1683 Time(s)
