tangerin
Posted: Fri Dec 30, 2005 5:50 am Post subject:
a few questions Subject description: from a future user |
i use a mac dual g5 with osx, motu 828mk2 and ableton live with reaktor for music production. Now after using the g2 demo in the past months (that totally convinced me) i'm going to buy a real g2 (engine).
But i have a few simple questions before ordering:
there's a way to route the audio to ableton live so i can record it
and keep it digital without plugging cables in my motu?
With the hardware i will see the NM like another interface?
I think it's the same with other softwares so i'd like to know how
you integrate the g2 with sequencers.
Second: i'm a studio producer, so i'll never use the g2 live,
do you suggest anyway a g2 keyboard instead of the engine?
I already have a remote 25, it's a big difference?
Third, it's necessary to add the expansion or for normal use
i can live without?
Thanks for now, this forum will be a great help! |
rnp
Posted: Fri Dec 30, 2005 6:01 am Post subject:
hi and welcome to the forum!
the G2 has no USB audio or midi interface, you only use the USB port to communicate with the editor software. so yes, you will have to plug in both audio and midi cables to use it with Ableton Live. It's like any other hardware synth, no integration like a Virus TI or TC Powercore for instance.
I've had the G2 keyboard for over a year now and have had the urge to buy the extension board a couple of times, but at my skill level it's usually my own fault when patches use up a lot of DSP - lean and mean programming goes a long way, so I haven't bought it yet. I love the interface of the keyboard, it's clever and very versatile. but for the difference in price you could get another synth, so it totally depends. if you try the keyboard out at a store you might not want to go back to the engine though ;_) _________________ http://www.regicide.org
deer music
offering temporary solutions |
Axiom
G2 patch files: 28
Posted: Fri Dec 30, 2005 6:03 am Post subject:
Hi and welcome,
1) sadly, the G2 usb port doesn't act as audio interface. You must plug it into your motu to record audio.
2) Since is not mandatory to have a keyboard, I can only suggest you heavily to have a keyboard version of G2 due to its front panel. I can't live without it Anyway, your Remote can do all you need to play the Engine but you will lack all Keyb version displays.
3) Like the previous answer, is not mandatory but heavy suggested when you will create some more heavy patches. Since something very useful and playable can be achived even with a mono-dsp micro modular, imagine how many things you can do with a G2 Engine as is
Luca _________________
Posted: Fri Dec 30, 2005 6:04 am Post subject:
AFAIK the G2 doesn´t have a digital out and no audio is piped into the USB connection. The USB is for is a dedicated connection between the editor application and teh G2, and it is not used for anything else. The audio output from the G2 is "analog". This means you will have to patch the G2 into your 828 and record it the same way you would be recording any other synth.
The "lack" of a digital audio output isn´t really a problem at all. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
tangerin
Posted: Fri Dec 30, 2005 6:30 am Post subject:
wow thanks for the fast replies, really very helpful.
The audio routing is not a problem,
i'll plug the cables to my motu.
But i'll go soon in a shop to try the g2 keyboard,
and see if it's another world respect to any other controllers.
For now thanks again.
Bye & happy new year! |
BobTheDog
Posted: Fri Dec 30, 2005 7:44 am Post subject:
| tangerin wrote: | wow thanks for the fast replies, really very helpful.
Hi There,
Before you play the keyboard in the shop it would be worth you downloading the manual and reading the sections on how the keyboard controls work.
Andy |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Fri Dec 30, 2005 8:11 am Post subject:
The panel is unlike other controllers. Imagine having 120 knobs to use (8 knobs x 15 pages). And the knob name and function appears above the knob in the dedicated LCD. And the LED knobs are sweet. Very nice when you turn the light off. When you assign a morph to a knob and you will see the knob split in 2 levels. very cool.
And of course, the panel allows you do what I can patch surfing. This may or may not be in the manual --- Make sure that you have the editor running when you check the G2 keybaord out in the store. With the editor running, hit the patch button on the G2 panel (next to the red store button). now the selected module can be controlled via the 1,2,3 parameter pages (bottom right corner of the panel). You can also select the module in the patch using the left/right/up/down buttons or the big knob below them. select a sequencer module and now you can tweak the sequence right from the panel like on an 808.
This is a very nice way to tweak patches, as you see all the connections and modules on the monitor, while tweaking them on the synth without even using a mouse (mouse is bad, knobs and buttons are good)
BobTheDog is right, if you have a chance read the manual before you hit the store (there is a section dedicated to the panel).
The expansion is a must IMO. It allows one G2 to use 200% patches (100% in the poly area and 100% in the fx area) in all 4 slots. Or you get more polyphony. It all depends how you use the beast.
Once you check it out, if you have any questions (about it or the patches) let us know!
/Dasz |
monobass
G2 patch files: 12
Posted: Fri Dec 30, 2005 2:31 pm Post subject:
| dasz wrote: | | The expansion is a must IMO. It allows one G2 to use 200% patches (100% in the poly area and 100% in the fx area) in all 4 slots. Or you get more polyphony. It all depends how you use the beast. |
My unexpanded G2 let's me use 100% in the poly and 100% in the FX.. I thought the expansion only added more polyphony like on the original NM? |
Joined: Apr 03, 2004 Posts: 24672 Location: The Netherlands, Enschede
Posted: Fri Dec 30, 2005 2:46 pm Post subject:
| _ Steve _ wrote: | | dasz wrote: | | The expansion is a must IMO. It allows one G2 to use 200% patches (100% in the poly area and 100% in the fx area) in all 4 slots. Or you get more polyphony. It all depends how you use the beast. |
That is true, but you can only do so in two slots and the unexpanded G2 will be full then. The expanded G2 can do it in four slots, that's what Dasz said, well it's what I read in it :-) _________________ Jan
monobass
G2 patch files: 12
Posted: Fri Dec 30, 2005 3:07 pm Post subject:
| Blue Hell wrote: | That is true, but you can only do so in two slots and the unexpanded G2 will be full then. The expanded G2 can do it in four slots, that's what Dasz said, well it's what I read in it  |
Ah I see. Damn I wish I could afford the expansion  _________________ Steve |
Posted: Sat Dec 31, 2005 10:11 am Post subject:
Well, those 200% patches aren't realy 200% as I see them. You can't have 20 connections between the two, for example. The different blocks run on different DSP's so when it comes down to it (aside from convenience) it's exactly the same as inter slot bussing, in fact the concerns, limitations and price (in system resources) is the same.
With a 200% patch you get it all on one schreen which is a advantage, by using two slots the second one could theoretically be used polyphonically with voices trigered by the first enabeling the use of simple "classes" in mid patch for particle-style techniques.
Looking at it that way you could have a 300% patch too.... For a expanded G2 it indeed becomes different but that expansion -as far as I know- doesn't increase the matrix for inter DSP comunication. Those lines are simply a bottleneck that nothing is going to get around. _________________ Kassen |
Rob
Joined: Mar 29, 2004 Posts: 580 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Sun Jan 01, 2006 7:55 pm Post subject:
| Kassen wrote: | | Well, those 200% patches aren't realy 200% as I see them. |
'200% patches' is a nickname that came into being when a limitation on the classic NM was discussed.
This 200% patch idea is of course not to be taken literally. In fact it is a reference to the total amount of DSP useage that a monophonic patch can use. By 200% is meant that on a G2 a single monophonic patch can use the power of up to two DSP's. On the classic NM a single monophonic patch could use only the power of one DSP that was also almost half as slow as a G2 DSP.
Still, on the G2 signal routing between these two DSP's is limited by what the hardware connection between these two DSP's can handle, which is up to four unidirectional audio busses from the 'voice'-DSP to the 'FX'-DSP, plus four bidirectional audio busses that are available in other slots as well. On the classic NM there were up to four unidirectional audio busses and no bidirectional 'interslot' busses.
The issue is imho basically a concern for those who switch from a classic NM to a G2, as it originally refers to a limitation of the classic NM that was positively dealt with during the development of the G2. A 200% patch indicates a certain relation between the classic NM and the G2, and is not a feature that has any relevance by itself. |
Posted: Sun Jan 01, 2006 8:02 pm Post subject:
But still .. I'm soo happy with these 800% patches, that I almost forgot about the limitations  |
monads
Joined: Oct 12, 2005 Posts: 115 Location: electroland
Posted: Thu Jan 05, 2006 10:24 am Post subject:
| Hi all! well I was looking at the G2 also, and so I understand it correctly...for patch creation you must use the editor? This can then be sent to the G2 for further tweaking but it all starts with the editor. Sorry, I'm sure this has been asked and I know I'm being lazy I just don't want to plow through the manual to find the answer. |
Joined: Jan 31, 2003 Posts: 18312 Location: Durham, NC
Audio files: 235
Posted: Thu Jan 05, 2006 10:47 am Post subject:
| monads wrote: | | so I understand it correctly...for patch creation you must use the editor? This can then be sent to the G2 for further tweaking but it all starts with the editor. |
That's about it. To put down modules and connect them with patch cords, you use the editor. You can tweak parameters and set variations without it. _________________ --Howard
my music and other stuff |
monads
Posted: Thu Jan 05, 2006 11:02 am Post subject:
| Much thanks Howard for the info and quick response. That's what I thought but wasn't sure. |
