Tempo LED & Ext. Clock Sync Display
PostPosted: Tue Jan 24, 2006 11:01 am    Post subject: Tempo LED & Ext. Clock Sync Display
Subject description: Adjustments to the display of Master Clock
There are 2 LEDs under each knob, and currently in the Patch Display, there is no way of seeing the beat according to the clock. I'd like for the second LED to indicate when a beat is occuring (MIDI Clock/24 then divided by some constant associated with the patch(such as 1/4, 1/3, 1/16, etc)).
Also, it'd be nice for the button to control Off > Run > Sync(ext). This would FORCE the clock to be under external sync only. Thus, when you stop your external sequencer, the G2 clock stops as well.
Some form of tap-tempo for the *master* clock would be a good thing as well, but I don't know how this would be implemented. Maybe this could show up in the global/patch display (along with the volumes of each patch).
I'd like for the Tempo of an external clock to be displayed in the "Master Clock" section. This isn't necessary but just nice.
