New Open-Source G2 Editor RFC
Page 1 of 3 [63 Posts]
Goto page: 1, 2, 3 Next
nord_balls
PostPosted: Tue Jul 23, 2024 11:13 am    Post subject: New Open-Source G2 Editor RFC Reply with quote  Mark this post and the followings unread
Hi all,
It seems that efforts to run brunov's open-source G2 editor on Apple Silicon are not moving forward. The current state is the editor is built to expect libusb binaries in /usr/local, but Apple in their infinite wisdom has made that a readonly FS so installing libs with brew are not visible to the editor build.
In theory this could be resolved with a rebuild. However, the Delphi compiler only runs on Windows, and the free Community Edition cannot cross-compile, meaning maintenance for non-Windows platforms requires an expensive license.
I've made some progress investigating a port of brunov's code. Currently my efforts are on a Java library, with the idea that said library could be used to build both desktop and mobile UIs using IDEA tech. So far I have basic communication going over USB to the G2 so I'm getting a good idea of what a library and an application would require.
I thought now would be a good time to ask the community about what would be the most maintainable approach. I have professional experience with Java and Haskell; I've ruled out Haskell for a number of reasons. Java has the advantage of being cross-platform, and there are truly free OpenJDK VMs to use so it is not dependent on Oracle.
However, TypeScript is an attractive option. I have basic familiarity and spent a little time with usb libraries there. My async/await fu is poor though, so when it comes time to stand up threads for dispatching messages it could get ugly. For standalone UIs I guess it's Electron shell or some other tech. The final advantage is being able to use pch-viewer code from ian-s and friends more or less unchanged.
Thus I'm looking for input, and then after that, help. I think G2 devotees such as myself are pretty desperate for a maintainable editor so I think moving away from Delphi is the right approach. However I can even be talked out of that if there are better ways to approach the pascal code!
The main question is what tech, and my proposal is Java, or TypeScript.
Java:
PROS:
- cross plaf, good desktop UI support, possible mobile support
- good support for threading + messaging
- usb library is fine (even there a little annoying getting apple ARM to work)
CONS:
- "eew java" -- not the most popular lang in open source. However the UI could be written in Kotlin with the library in java. The library itself could even be in Kotlin ...
- no code to reuse, everything must be ported. Not too bad in itself but more work.
TypeScript:
PROS:
- lots of devs out there, "modern"
- also cross-plaf, possible browser-based execution via webusb (???)
- usb library is good
- reuse pch-viewer code
CONS:
- Still javascript, so not sure how robust the messaging layer will be. Probably fine but I personally don't have exp with that
- Desktop UIs via Electron is ... unknown how good an experience that will be?
- Not sure what mobile path is (but there probably are many)
And finally,
Delphi:
PROS:
- done, working where it works
CONS:
- very few devs available I think
- Weird, non-modern lang (I'm more familiar now that I've ported some of the USB code, but man what a weird language. Case insensitive what what what??)
- $$$ non-open compiler toolchain for cross-plaf build
- Windows-only IDE
Stuart
Burp
G2 patch files: 7
PostPosted: Fri Aug 09, 2024 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stuart,
A realy great idea and indeed very welcome! Would love to edit my G2 with my Mac M1 and it's nice screen.
I also thought about this and i also did some testing with javascript and webusb. Had some very basic communication working but nothing ported yet.
I also had the idea of using (and improving) ian-s pch-viewer code for the UI part. At least as a starting point. I allready did some changes there to have some feel for it.
My take would be web-based (so javascript/typescript) so there are lots of devs and that would make it easier to maintain. But the USB part should be tested first, if it could work.
There are options to make webbased apps into 'native apps' like the electron approach.
Allthough i'm a bit hesitated to jump into a time-consuming project, maybe we could join forces? And hope some more devs will jumps in?
Cheers!
-Jan (NL)
By the way, i am a (frontend) developer for a living.
if you don't know where you're going, you will allways arrive
nord_balls
PostPosted: Fri Aug 09, 2024 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan,
I've plowed ahead in Java, mainly on the USB but also file parsing. You can see my progress here: https://github.com/sirlensalot/g2lib
A big learning is that for G2 USB, you really need an asynchronous "read thread" even if you're just sending request-response. In Java I'm comfortable enough to be able to handle setting up a long-running thread and using a blocking queue etc for cross-thread messaging. But in JS I have absolutely no idea, and threading is one of those things you want to get right Smile
I would be happy to work on a JS project and could probably contribute quite a bit, if you or someone could set up the messaging framework + read thread + queue properly. I don't know how far you got with WebUSB but I have working java code here showing the basic interactions: https://github.com/sirlensalot/g2lib/blob/main/src/main/java/g2lib/Main.java#L37-L121
That's terrific. The UI work is really the hardest part in the end and ian-s's stuff looks great!
Can't argue with you there Smile
Once the framework is set up I've been testing with my rack G2 quite a bit so can help out there.
Sure, and to be honest I don't care if it's in the browser, I'm just not familiar with using a browser to do things like local USB. If it works I'm fine with it!
That sounds good to me! I can even help with the UI once the patterns/architecture becomes clear with how a UI twiddle sends off a USB message, or receiving a meter update message repaints the UI, etc.
So the main things I can't do initially are the threading and queueing stuff, and then hooking all that to the UI. Once that is basically there, I'm quite comfortable with the binary formats now so I'm confident we can make progress from there.
Stuart
Audio files: 316
PostPosted: Fri Aug 09, 2024 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll not contribute directly as I've moved away from the nords - but still two g2's are in my rack and I will be happy to crittically try things out on an old 32 bit mac (mojave 10.14.6) and a win10 pc.
Anyway - great to see something happening here!
Burp
G2 patch files: 7
PostPosted: Thu Aug 15, 2024 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought about it a bit more.
As i first thought the webUSB (and JavaScript/TypeScript) way was the way to go due to more developers can help/understand it. But webUSB is not a standard. There is a reason that not all browsers (Firefox) support it. It has some major security risks that probably will decrease the change of being a well settled standard. Although those risks in our case are small, the fact that it is not a well settled standard is a problem for our goal.
So maybe the Java route is the better. I'm not familiar with Java but maybe you can reflect on this? Is it a safe route to go for support, opensource etc? My guess is, it is. And is it possible to compile/run Java applications on other devices then desktop (macOS,Windows,Linux)? For example android and iOS tablets, or simple raspberry Pi's (which run a Linux clone)?
How is Java at GUI's?
Apart from the technical thoughts, i still have hesitations to join full in. Because lot of other responsibilities and hobby's (music is one of them Wink.
But what i definitely like to do is, same as Blue Hell, test it with my stack (Expanded G2 keys, MacBookPro 14" M1). And i'd also can read/review your code now and then to see if i understand it. And maybe, maybe... i'd help out with the UI part. That's where my heart is more than the lower level tech stuff.
What i also can do is fork ian-s patch viewer and commit my changes to it.
A a first step: can you add some minimum information to your repo how to run it and test it? Then i'm glad to test what you have build.
nord_balls
PostPosted: Fri Aug 16, 2024 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
If that is the case, I might still argue for an Electron app, mainly to preserve the ian-s UI. Electron doesn't have to use WebUSB, the npm usb package has a "native mode" that wraps libusb.
Not as good as Javascript? Smile
Kotlin has more mindshare than Java, but that's probably mainly for Android. Otherwise you're using ancient tech like Swing or JavaFX. Java's main advantage is it will _definitely_ work on mac/windows/linux desktop (and probably raspberry), but it's not a slam dunk for Android necessarily, and iOS is unknown territory. Oh, and the open-source part seems fine with OpenJDK and Temurin and friends.
Java's usb4java library seems less actively-maintained than npm usb. I had to search the web for a native jar to get it to work on M1 ... not a showstopper, but the point is Java isn't a perfect choice for USB either. Not sure what is at this point ...
I get it. I'm at a point in my life where a hobby like this is attractive to me, but I want it to have a maintainable future too so that I can eventually hand maintenance to some other user. Testing help will always be welcome!
(BTW it's not really needing testing yet. It's barely at hello-world status Smile, and I'm not going to do further work on it until I'm satisfied we've chosen the right architecture.)
Please do! If you have any electron experience, could you possibly investigate getting it to launch in electron? I can probably get low-level JS help from some professional colleagues if I just have an environment that can build.
NordG3
PostPosted: Thu Aug 22, 2024 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
All I care is for your port to be Sequoia and upward compatible and please make the interface have zoom up to 175% of the whole GUI and please render the new version by early 2025 for us Mac M5 compatible if possible.
Burp
G2 patch files: 7
PostPosted: Thu Aug 22, 2024 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did not know that. That makes the Electron case (with web technologies) a much stronger one.
That is again in favor for Electron with Javascript etc Wink
I don't have Electron experiences. But it has my intereset for some while. Porting ian-s patch viewer to an Electron app is a nice testing usecase, and a nice step for a new G2 editor. Good idea. Now finding some time Wink
Burp
G2 patch files: 7
PostPosted: Thu Aug 22, 2024 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are welcome to help!
NordG3
PostPosted: Thu Aug 22, 2024 11:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure what you mean but if you mean help coding I can't learn coding. I may be interested in testing early releases on macOS Sonoma or Sequoia though if that's what you want.
Burp
G2 patch files: 7
PostPosted: Thu Aug 22, 2024 11:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Every help is welcome, even testing, so yess great if you will. But first there needs to be something to test offcourse. And that will take some time.
Burp
G2 patch files: 7
PostPosted: Fri Aug 30, 2024 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I managed to get ian-s pch-viewer (with some changes) into an electron app. I tried contacting him (pm) before i put this on a GitHub repo, i don't won't too pass him. But no reaction yet.
This relative simple experience with electron was good. It feels like a good way too proceed. I also tried their basic webUSB example too see if my Nord is seen by it (nothing more). And that works.
Anyone has an idea to contact ian-s?
Audio files: 316
PostPosted: Sat Aug 31, 2024 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to draw his attention too to this thread - also a forum pm - but he did not see that message yet.
He seems to have an email link under his posts and when still usuing the same address .. using that may work … so maybe try find a post of him Cool
Burp
G2 patch files: 7
PostPosted: Mon Sep 02, 2024 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, i'll try to find it Wink
ChrisPurusha
PostPosted: Mon Sep 09, 2024 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Pasted from the other thread: I'm starting to nibble around the edges of getting comms working with the G2, possibly as a basis for an editor. Partly to get me further into XCode.
Looking at the Delphi open-source editor, it seems to use libusb. Not sure that's required though.
Possibly the iousb stuff Apple has might be a better mechanism?
Anyone have experience with this stuff? Any pointers?
ChrisPurusha
PostPosted: Mon Sep 09, 2024 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
For what it's worth, I've got something based on the example code linked below working. It's seeing the G2 on USB. So - first step taken!
https://github.com/opensource-apple/IOUSBFamily/tree/master/Examples/USBSimple%20Example
ChrisPurusha
PostPosted: Mon Sep 09, 2024 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Currently wondering whether to jump for something based on JUCE, Objective-C or Swift.
Maybe if there’s a good G1 editor with the right framework, that’s maybe the way forward?
ChrisPurusha
PostPosted: Tue Sep 10, 2024 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Slow progress, but does seem to be progress.
I'm currently attempting to get the initialisation message out of the Mac, into the G2...
I've got WireShark running on my old Mac with the original G2 editor. That combined with info on the link below - it's tying up.
https://www.bverhue.nl/G2EditorHelp/G2_messages.html
ChrisPurusha
PostPosted: Thu Sep 12, 2024 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: I have some 'C' working on the Mac, which is reading/writing data to/from my G2!
NordG3
PostPosted: Thu Sep 12, 2024 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Can someone tell me if the Windows G2 Editor v1.62 available on the NordKeyboards.com homepage is known functional on new Windows 11 x64 Intel computers? If not I would love to have a Windows Delphi G2 FMX app recompiled for my G2 Engine I just bought. I kept getting crashes on the G2 FMX app on macOS Sonoma 14.6.1 that required restarts after the editor disconnected me but I enjoyed the G2 for awhile.
Burp
G2 patch files: 7
PostPosted: Mon Oct 07, 2024 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice! Can we see your progress somewhere?
ChrisPurusha
PostPosted: Tue Oct 08, 2024 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Nothing super special to show at this point. I've been busy job-hunting, which seems to be a full-time job.
Where I am - I've got the foundations of an event driven state machine doing USB comms alongside other potential events. All in 'C' as-is. I'm going to have to work out which language to jump to for the GUI. I don't know Swift nor Objective-C, so unless I can get a GUI working with C++ or maybe use JUCE, I'll have a learning curve.
No approaches by GUI guys so far.
ChrisPurusha
PostPosted: Thu Oct 24, 2024 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I’ve ditched Libusb and am now going direct to IOKit.
For those who reckon the Delphi editor is suffering from the Libusb thing, I could potentially share my IOKit work in ‘C’, which could be used to modify the Delphi editor, removing Libusb?
I don’t have a Delphi compiler though.
Starting to attempt to learn Swift for the GUI, but it’s a slow process. Someone with more experience who was willing to pick up the GUI bit would push things forward significantly I reckon.
ChrisPurusha
PostPosted: Sat Nov 02, 2024 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm hoping to publish my code in GitHub soon as open-source.
It's very much a starting-point. Most of the problems I've had, have been related to IOKit. I feel like I have a pretty good solution to that now.
It's all 'C', which might need to be translated to Swift or Objective-C for GUI. Lots of message types to add. Struggling with the actual patch data message, since bverhue's work is great and has been immensely helpful, but doesn't describe the patch data responses format/protocol.
Another problem I've hit, is when loading a new patch, the G2 refuses to give me patch data for the new patch unless I power cycle it. There must be a special message I need to send to reset it. Init(ialisation) doesn't clear that problem. I'll probably need to fire-up Wireshark again to see what happens on the original editor. ...or I see how bverhue deals with it in Delphi, if that app does in fact deal with it.
ChrisPurusha
PostPosted: Mon Nov 04, 2024 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the work in progress. This pretty-much goes through the initialisation sequence and dumps the data to the console as-is. Then polls for continuous data such as volume or LED status.
https://github.com/chrispurusha/G2-Edit
If anyone wants to help with the GUI side of things, please do drop me a line.
