Variation sequencing ?
Page 1 of 1 [16 Posts]
onosendai
G2 patch files: 4
PostPosted: Thu Feb 15, 2007 4:38 pm    Post subject: Variation sequencing ? Reply with quote  Mark this post and the followings unread
I would like to chain variation with a sequencer or LFO. Do you know if it's possible ?
Audio files: 262
PostPosted: Thu Feb 15, 2007 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes that is possible, like in attached patch (load into slot A).
CC70 controls the variation.
var-seq.pch2
variation sequencing
 Filename:  var-seq.pch2
 Filesize:  942 Bytes
 Downloaded:  2089 Time(s)
onosendai
G2 patch files: 4
PostPosted: Thu Feb 15, 2007 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
The G2 is amazing...
Edit : Wow ! Changing value during Var Seq make crazy sequences, especialy if you change LFO value. Really great.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Feb 15, 2007 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
yup. it is pretty fun have you played around with RedMonday_DZ.prf2 or BCHydro_DZ.prf2?
I like to do this with my hands hitting the buttons as I like to improvise often, (too bad there is no sequencer combined with am 8 switch out there to make variation adjustments in realtime just a little bit quicker).
Once you get good at it, it is a lot of fun to tweak this way.
/Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
Audio files: 262
PostPosted: Fri Feb 16, 2007 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even from within the editor this is fun (using the number keys).
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Feb 16, 2007 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, totally!!!
but not the same as with the panel. I like the spacing and feel of the g2 panel variation buttons, also they light up so you always look at the keys and see the selected variation to boot.
/Dasz
http://www.dasz.com
Audio files: 262
PostPosted: Fri Feb 16, 2007 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, but considering the price difference Wink
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Feb 16, 2007 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know.
I have set up my pc1600 as a variation switcher (8 buttons which send different cc70 x 2) in addition to the panel (for switching variations on multiple slots at once).
/Dasz
http://www.dasz.com
sebber
G2 patch files: 33
PostPosted: Mon Jul 02, 2007 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Any ideas how I can trigger Var. 2 by an event in Var. 1, then trigger Var. 3 by an event in Var. 2? Both the machine and I are going nuts trying to solve this Confused
Fish don't swim. They dive.
For everything else: The Patcher's Toolbox
Audio files: 262
PostPosted: Mon Jul 02, 2007 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing I'll have a try this evening when noone else was sooner. An event is a logic signal going from false to true? Are the events from different modules in the different variations, or do they come from one module?
sebber
G2 patch files: 33
PostPosted: Mon Jul 02, 2007 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan, I thought of a sequencer in Var.1 whose link output links to the same sequencer in Var. 2, then 3... Sort of like 8 sequencers in a row but each in a different Variation.
Everything I tried goes berserk because it changes the CC70 output immediately. I knew I'd run into trouble because I remembered this post:
http://mail.electro-music.com/pipermail/nord-modular/2004-December/001382.html Laughing
The innovative concept of the G2 shows new ways in sound synthesis: AmplitudeModulation, FrequencyModulation, VariationModulation Shocked
Audio files: 262
PostPosted: Mon Jul 02, 2007 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah well, Rob obviously was in a bad mood at the time Very Happy I would like to have a button though to block and unblock variation changes.
Do you have an example patch Sebastian? It's not directly clear to me what you mean, an illustration might be helpful.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Jul 02, 2007 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sebber, I use s/h modules driven by a clock so variation changes occur at well defined (rhythmically) times. See BCHydro_DZ or RedMonday_DZ in the factory soundset. If you turn the variation seq switch off (slot A, page A-1, knob 1), then you can try this out with the other 3 knobs (which change the variations in slots B,C,D respectively), but only on the downbeat.
I'm not sure what you mean by the sequencer control in the other slots as you describe, can you elaborate?
/Dasz
http://www.dasz.com
Audio files: 262
PostPosted: Mon Jul 02, 2007 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this a bit like what you meant Sebastian ?
var-seq.prf2
 Filename:  var-seq.prf2
 Filesize:  3.53 KB
 Downloaded:  1932 Time(s)
sebber
G2 patch files: 33
PostPosted: Tue Jul 03, 2007 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Ja(aaan), that's it. Exactly. And I wouldn't have come to it by myself like using the S-flipflop. I just replaced it with the pulse module like I had it and mayhem again. Is the S-flipflops Q-output impuls simply much shorter than the shortest pulse outputs pulse Question
Dasz, I always like to listen to Monday and Hydro, they are great. What I needed though is not a preprogrammed pattern but a Variation change trigger from "within" a variation.
Thanks a lot both of you!
Audio files: 262
PostPosted: Tue Jul 03, 2007 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
It gets reset at the moment the new variation starts (see wire on reset input), I needed that to make it work.
