 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
synth organ
Page 1 of 1 [6 Posts]
ethnix73
G2 patch files: 6
PostPosted: Sat Apr 14, 2007 5:49 pm    Post subject: synth organ Reply with quote  Mark this post and the followings unread
this is my first g2 patch....a kind of synthetic organ...with no controller Embarassed
synth organ.pch2
 Filename:  synth organ.pch2
 Filesize:  3.37 KB
 Downloaded:  1734 Time(s)
Audio files: 309
PostPosted: Sat Apr 14, 2007 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome for now, can't listen at this computer.
Audio files: 309
PostPosted: Sat Apr 14, 2007 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, wait, I can listen actually, got the demo installed on this one PC. Sounds good on the demo.
ethnix73
G2 patch files: 6
PostPosted: Sun Apr 15, 2007 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply.
Comments are appreciated....
TB2006
G2 patch files: 17
PostPosted: Sun Apr 15, 2007 5:44 pm    Post subject: Re: synth organ Reply with quote  Mark this post and the followings unread
Welcome here, i hope you will have a lot of fun with your G2.
Some comments :
Mix 2 1B1 is not connected to the circuit (no output connected)
You put 2 low pass filters in serie, that does not make much sense, you
could as well have one filter with a bit different setting.
The clocksignal does weird things with the LFO: if you put it off, it is different, but if you put it on, changing the frequency of the clock does not influence the LFO. You could have taken a second LFO to modulate the first one.
There is no input connected to the wave wrapper.
Not so easy in the beginning, isn't it? but you will surely learn a lot, there are some old beginners like me, but better, there are a lot of very experienced and clever programmers here, you will have a hard time before you understand all of their tricks. (i don't !)
But what you are doing is perfect: go for it, try everything, and enjoy!
Tim
ethnix73
G2 patch files: 6
PostPosted: Mon Apr 16, 2007 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply and comments...
" You could have taken a second LFO to modulate the first one". I've just done it and it gives an interesting result.
