Using MIDI to jump between variations
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
lamefrillery
G2 patch files: 5
PostPosted: Sat Aug 11, 2007 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I think that's what it was. I went back to my original file and rebuilt the var jumping set up that you showed me. It's running smoothly for the most part. What I think I need now is some sort of a command to reset the sequencers when I jump between vars. I've got what I'm working with currently attached and you'll see what I mean.
Wood Man.pch2
 Filename:  Wood Man.pch2
 Filesize:  4.75 KB
 Downloaded:  1420 Time(s)
PostPosted: Sat Aug 11, 2007 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
The status module, from the in/out tab, will give a pulse on it's var. active output when a variation change occurs, you can use that one I think.
lamefrillery
G2 patch files: 5
PostPosted: Sat Aug 11, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm still running into a problem where when I change between vars the parking comes undone for the sequencers I have linked. Since I have two seperate parts with two linked sequencers each, right when I change vars I hear four things at once when I should only hear two. When I toggle the reset button everything sounds fine or if I play a few notes it'll go back to normal, but it's still not letting me do it automatically when I change vars.
PostPosted: Sun Aug 12, 2007 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not really into sequencing myself but I know there are some issues on how to set up linked sequencers. Maybe someone else can step in here?
