Other equations ....
Page 1 of 1 [20 Posts]
JLS
G2 patch files: 316
PostPosted: Thu Aug 23, 2007 2:27 pm    Post subject: Other equations ....
Subject description: Equations used as pattern generators
scalar wave definition equation (dx^2+dy^2+dz^2)^1/2
equation is only approximately but generate nice sound pattern Smile
[editor's note: changed the subject line a little. --mosc]
Scalarwave.pch2
scalar wave
 Filename:  Scalarwave.pch2
 Filesize:  1.54 KB
 Downloaded:  2196 Time(s)
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
JLS
G2 patch files: 316
PostPosted: Wed Aug 29, 2007 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
E=m*c^2
only fun but produce usefull pattern Smile
Einstein-algo.pch2
 Filename:  Einstein-algo.pch2
 Filesize:  1.32 KB
 Downloaded:  2128 Time(s)
JLS
G2 patch files: 316
PostPosted: Tue Sep 25, 2007 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Other chaotic system
fn(Xi)=LXi(1-Xi)
Smile
ChaosGen.pch2
fn(Xi)=LXi(1-Xi)
 Filename:  ChaosGen.pch2
 Filesize:  1.46 KB
 Downloaded:  2132 Time(s)
Audio files: 235
PostPosted: Tue Sep 25, 2007 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, you changed your user name. Confused
JLS
G2 patch files: 316
PostPosted: Tue Sep 25, 2007 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes new user name Smile
Audio files: 235
PostPosted: Tue Sep 25, 2007 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, at least you didn't change your avatar at the same time. That would really get confusing... drunken
Audio files: 310
PostPosted: Sat Sep 29, 2007 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patterns !
Here is a mod on it, just some different notes and a different beeper. Oh, and just a tiny bit of sand in the machine Very Happy
chaosgen_bh.pch2
mod on a patch by JLS
 Filename:  chaosgen_bh.pch2
 Filesize:  2.99 KB
 Downloaded:  3075 Time(s)
JLS
G2 patch files: 316
PostPosted: Wed Oct 03, 2007 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Logistic Equation
fn(x)=r*xi*(1-xi)
Two version first in chaotic mode and second with time line Smile
 Filesize:  26.05 KB
 Viewed:  56133 Time(s)
LogEqua.pch2
Logistic equation
 Filename:  LogEqua.pch2
 Filesize:  1.39 KB
 Downloaded:  2142 Time(s)
TiLogEqua.pch2
Logistic equation with time factor
 Filename:  TiLogEqua.pch2
 Filesize:  1.72 KB
 Downloaded:  2047 Time(s)
JLS
G2 patch files: 316
PostPosted: Wed Oct 03, 2007 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
My new patch Logistic Equation is same equation like ChaosGen patch but using other patching (better algo)
Smile
JLS
G2 patch files: 316
PostPosted: Wed Oct 03, 2007 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Same algo but other timeline with feedback Smile
TiFdLogEqua.pch2
other timeline
 Filename:  TiFdLogEqua.pch2
 Filesize:  1.75 KB
 Downloaded:  1979 Time(s)
JLS
G2 patch files: 316
PostPosted: Sun Oct 07, 2007 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
modified version LogEquation
Fn(x)=sin(x+rx(1-x))
Smile
LogEquax.pch2
sin(x+rx(1-x))
 Filename:  LogEquax.pch2
 Filesize:  1.64 KB
 Downloaded:  2043 Time(s)
Audio files: 310
PostPosted: Mon Oct 15, 2007 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah and another one with different notes Very Happy
This one can be modulated through the phase input of the LFO, I likethat - like in the attached patch.
logequax_mod.pch2
 Filename:  logequax_mod.pch2
 Filesize:  1.73 KB
 Downloaded:  2910 Time(s)
Audio files: 235
PostPosted: Tue Oct 16, 2007 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
These patches are interesting. I know they aren't intended to demonstrate sound quality, but melody generation. But still, they sometimes annoy me because of the pure mono characteristic of the sound.
When listening to these on a stereo system one hears some of the problems with stereo, especially the "hole in the middle" problem. If the same signal is coming from two speakers, as soon as the listener moves off axis toward one of the speakers the sound seems to come only from that closest speaker. I was reading how the THX people solve this problem for the two rear speakers - they frequency shift slightly the mono signal. I decided to try that on this patch. I'd be interested in hearing what people think about it. You can do A/B comparisons by pushing the active/bypass switch on the frequency shifter. Different shifts provide different results.
logequax_mod_fs.pch2
Melody generator by JLS and Blue Hell with frequency shifter added to improve stereo.
 Filename:  logequax_mod_fs.pch2
 Filesize:  1.79 KB
 Downloaded:  3291 Time(s)
JLS
G2 patch files: 316
PostPosted: Tue Oct 16, 2007 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Great collaboration guys Smile
Audio files: 310
PostPosted: Fri Oct 19, 2007 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes that shifting thing is a nice one, usually I modulate the shift as well Very Happy
JLS
G2 patch files: 316
PostPosted: Fri Nov 09, 2007 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Double mandelbrot
x^2+cy
y^2+cx
Smile
DoubleMandel.pch2
 Filename:  DoubleMandel.pch2
 Filesize:  1.69 KB
 Downloaded:  2018 Time(s)
JLS
G2 patch files: 316
PostPosted: Fri Nov 09, 2007 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
HoloMandel
x=x^2+cy
y=y^2+cx
fn(z)=x^2+y
Smile
HoloMandel.pch2
 Filename:  HoloMandel.pch2
 Filesize:  1.52 KB
 Downloaded:  2194 Time(s)
deb76
PostPosted: Tue Nov 13, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Waow, with nice echo this patch play with style Terry Ryley. Thanks.
Audio files: 310
PostPosted: Wed Nov 14, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome deb
JLS
G2 patch files: 316
PostPosted: Tue Nov 20, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Chladni kyma-wave equation Smile
f=(m+2n)^2
Cyma.pch2
f=(m+2n)^2
 Filename:  Cyma.pch2
 Filesize:  1.38 KB
 Downloaded:  2104 Time(s)
