external triggers and audio 'snipper' with variation sequenc
Page 1 of 1 [3 Posts]
Fozzie
G2 patch files: 49
PostPosted: Mon Jul 05, 2004 1:16 pm    Post subject: external triggers and audio 'snipper' with variation sequenc Reply with quote  Mark this post and the followings unread
I am trying to sequence through variations in this patch, that uses an external sampler for rythm and a guitar on in-3. Thing is, when it should go to variations other than 1, the audio distorts and the display on the computer freezes. Any ideas? Bug? Wait for 1.2, whenever that may be Confused ?
External sampler_guitarIN_cutoff6.pch2
Guitar snipper on in3, external GMdrum sampler on in1&2. Variation sequencing doesn't work as expected. Bug?
 Filename:  External sampler_guitarIN_cutoff6.pch2
 Filesize:  4.02 KB
 Downloaded:  1822 Time(s)
Audio files: 309
PostPosted: Mon Jul 05, 2004 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I didn't have a look at the patch yet (G2's not unpacked yet after the NM event), but as it's a patch and not a performance you must be changing the variation from the patch itself. As the variation selection is also part of the things changed by the variation machinery, you're in for for potential big trouble.
It will be very hard (if not impossible) to get things working as wanted this way. Try to select variations from another slot, it will save you from a headache :-)
Jan.
Fozzie
G2 patch files: 49
PostPosted: Tue Jul 06, 2004 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan, that was indeed what I was trying to do. And indeed, it is quite bothersome to construct. I'll continue in the way you suggest, I guess, and make performances. Still, strange things do happen when you do it in one slot, if anyone cares.
