 Forum index » Clavia Nord Modular » G2 Performances - Experimental
slow analog style noodle
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Aug 03, 2004 1:57 am    Post subject: slow analog style noodle Reply with quote  Mark this post and the followings unread
An exercise in analogising in slot A.
It was mentioned on the list about using the clocked random generator to modulate the frequency of the oscillator clocking it. I had used a divider as suggested which produces some interesting results. In this case however, the random module is clocked directly for the first two oscillators. A third oscillator is modulated by a level scaler and one of the random signals. This combined signal is also fed back a little into the master oscillator controlling the pitch of all three oscillators. No big plan really, just some random experiments. The results are pretty subtle.
This is the first time I have used the built in arpeggiator in a noodle.
It is also not as sombre or dark as my usual efforts. You can turn the tempo up to 150+ BPM for a less calming variation.
analog-slow.prf2
analog style noodle
 Filename:  analog-slow.prf2
 Filesize:  12.31 KB
 Downloaded:  1653 Time(s)
Audio files: 163
PostPosted: Tue Aug 03, 2004 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite beautiful, Ian... thumb up
