Splitting a chord across multiple sounds
Page 1 of 1 [5 Posts]
Aesoteric
PostPosted: Sun Sep 14, 2008 12:06 pm    Post subject:  Splitting a chord across multiple sounds Reply with quote  Mark this post and the followings unread
Hey all,
I haven't been around in a while...things have been really hectic, but now I'm back from producer duty and working on a couple of tracks of my own stuff (which seems like an exciting novelty at the moment!), I'm trying to put together a few new things on the G2.
I want to be able to play a chord or series of overlapping notes and have each note trigger a different oscillator/FX path. I've stuck together a really quick starting point, but its results are unpredictable.
If anyone has two minutes to nose at it, call me an idiot for missing something obvious and point me in the right direction I'd be hugely grateful...
TJ
Chord split.pch2
 Filename:  Chord split.pch2
 Filesize:  1.92 KB
 Downloaded:  1868 Time(s)
Audio files: 308
PostPosted: Sun Sep 14, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not exactly sure what you mean .. as long as you play the patch you sent monophonic things seem to be ok to me ... but I've no keyboard so I can't really test it.
Audio files: 308
PostPosted: Sun Sep 14, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you mean something like this?
Added the red modules to hold the notes after they were played.
Edit : Just remove the stuff I put in the fx section to play the patch from the keyboard. Fun patch BTW!
chord_split_136.pch2
 Filename:  chord_split_136.pch2
 Filesize:  2.52 KB
 Downloaded:  2782 Time(s)
PostPosted: Sun Sep 14, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, confusing. I rearranged stuff into this patch, that doesn't work either - I can't for the flie of me figure out why.
I am guessing you should crank up the voice count though.
/Stefan
chord_split_136_sbt1.pch2
 Filename:  chord_split_136_sbt1.pch2
 Filesize:  2.04 KB
 Downloaded:  2283 Time(s)
Audio files: 308
PostPosted: Sun Sep 14, 2008 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and the multiplexer stuff is not needed of course when sample&holds are used ... hope I didn't complicate the patch too much in the mean tiem.
chord_split_137.pch2
 Filename:  chord_split_137.pch2
 Filesize:  3.02 KB
 Downloaded:  2869 Time(s)
