today> Twyndyllyngs Live via Ninjam tonight Chez Mosc
tips for using clock sync'ed lfos?
Page 1 of 1 [2 Posts]
rhombus
PostPosted: Fri Mar 06, 2009 7:07 pm    Post subject: tips for using clock sync'ed lfos? Reply with quote  Mark this post and the followings unread
I've been tinkering around with using clock sync'ed lfo's for making rhythms and I could use some tips from you all on using them, especially keeping them in sync when the rate is changed. Also, I need a method of offsetting an lfo if I wanted to start it on the up beat rather than the down beat, for example for a standard kick/snare combination. Also, is this idea more crazy than it's worth? Will I just end up eating more DSP power than just working with lots of sequencers?
View user's profile Send private message AIM Address MSN Messenger
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Mar 07, 2009 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
One idea is to use a ShapeLFO with Direction set to zero, so it doesn't oscillate anymore, but rather acts as a waveshaper. A second LFO, which is clock-synced and set to sawtooth, will act as a driver for this waveshaper. By multiplying this driver LFO by 2,3 or 4 and connecting the results to a 4-1 switch, you can drive the waveshaper (modulate its phase) at 4 instantaneously selectable speeds, but without ever losing sync with the MIDI clock when switching around. Also, the Phase control knob of the ShapeLFO neatly serves as an offset in your intended fashion.
I used this approach some time back with my DeluxeLooper patches.
Example attached.
tim
SyncLFO TK.pch2
Clock synced LFO. Switch between speeds without losing sync.
 Filename:  SyncLFO TK.pch2
 Filesize:  1.62 KB
 Downloaded:  1139 Time(s)
