 Forum index » Clavia Nord Modular » G2 Performances - Noodles
KLEUR
Page 1 of 1 [9 Posts]
mother misty
G2 patch files: 130
PostPosted: Thu Dec 02, 2004 1:30 am    Post subject: KLEUR Reply with quote  Mark this post and the followings unread
The result of a night of noodling...
((let it play for a while, it makes some very interesting changes Smile
some info...
SLOT A / ROOD
contains a phase & string oscillator, serial connected.
Pitch from both oscillators is controlled from a rnd pattern module
and feeded trough a key quantizer.
The phase osc receives audio from bus 1, 2 , 3 & 4 (Slot D, VA & EFX part)
This slot generates the notes, check the variations for other presets
SLOT B / GEEL
contains an experiment with 12 voice filters & 12 bandpass filters
modulation is controlled by 3 shiftregister delays
Receives audio from bus3 (Slot D)
SLOT C / BLAUW
another experiment, this time with the reverb tail from bus1
feeded trough a stringoscillator & controlled by a sequencer
SLOT D / GROEN
based around one of my other experiments "pascae.pch"
but I've added alot of stuff. The output from the vocoder is
routed to bus 1&2 (Slot A, C) & the output from the FX
area is routed to Bus 3&4 (Slot A, B)
Enjoy!
KLEUR.prf2
Performance noodle
 Filename:  KLEUR.prf2
 Filesize:  17.35 KB
 Downloaded:  1869 Time(s)
KLEUR-Audio1.mp3
An audio example of KLEUR
 Filename:  KLEUR-Audio1.mp3
 Filesize:  1.52 MB
 Downloaded:  1097 Time(s)
KLEUR-Audio2.mp3
another audio example of KLEUR
 Filename:  KLEUR-Audio2.mp3
 Filesize:  1.49 MB
 Downloaded:  1098 Time(s)
G2 patch files: 626
PostPosted: Thu Dec 02, 2004 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Those mp3's are beautiful. Will have to ask my less than enthusiastic local dealer again about an expansion card.
mother misty
G2 patch files: 130
PostPosted: Thu Dec 02, 2004 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Well......... it's almost santa! Very Happy
Audio files: 235
PostPosted: Thu Dec 02, 2004 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful. You are right, over time things change. Thanks much.
Audio files: 310
PostPosted: Thu Dec 02, 2004 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Mother !
'laser show' with vocoder looks nice as well :-)
Jan.
mother misty
G2 patch files: 130
PostPosted: Fri Dec 03, 2004 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys!
I'm trying to strip down this version so that it will also work on an unexpanded G2, but I've some questions about the limits of the patchload
If I want to make this work on an unexpanded G2,
should the patchload in all slots be max.
VA: 100% (cycles) 50% (memory)
FX: 100% (cycles) 50% (memory)
Audio files: 310
PostPosted: Fri Dec 03, 2004 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
No not quite, it seems to be a bit complicated this voice allocation thing :-)
Each DSP has 100% cycles and 100% memory.
Then you must see how many voice-sections (a word made up by me) you have. An FX area of a patch is one voicce-section and a VA area is as many voice-sections as there are voice requests.
Then in this case you've got four DSPs that the voice-sections must fit in.
To fit on a DSP means that the sum of the cycles over the voice-sections may not exceed 100% and likewise for the sum of the meemory percentages may not exceed 100%.
So when you want to be sure, keep all resources <= 50%, but you can exchange things. Say when you have one voice-piece that uses 40% memory and 40% cycles then another patch with 60% for both atributes will fit on the same DSP.
But neither for memory nor for cycles can you exceeed 100% for any DSP.
This puzzle can get quite complicated, beest to have a computer program to calculate this.
Jan.
mother misty
G2 patch files: 130
PostPosted: Fri Dec 03, 2004 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for clearing that out...
A DSP calculator would indeed be a very helpful tool for such things Smile
cappy2112
PostPosted: Thu Apr 28, 2005 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Mother !
'laser show' with vocoder looks nice as well Smile
Jan.
Now that my Engine is working- this was one of the first ~10 G2 Noodles I've heard.
Not realizing what Jan is referring with the Laser show & vocoder references, I started looking around for a patch called laser show, while the patch was downloading. Smile
Now I can see the vocoder module now. It reminds me of Jean-Michel Jarre's Laser Harp- somewhat...
Very impresseive!
