midi delays using DelayClock
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Sep 16, 2009 10:34 pm    Post subject: midi delays using DelayClock Reply with quote  Mark this post and the followings unread
Hey all,
For the longest time I have not used the clocked Delay module.
I have figured out how to implement a midi delay using it with the sequencers in Trigger mode (in gate mode, it is dead easy since the gate times are long enough to be properly sampled into the clocked delay).
The issue seems to be how long to sample and hold the gate at every step. if i used gate mode I do not have to use the inverted envelope to reset and hold at each step to ensure that event get triggered after the appropriate times (I implemented 2 sequence delays of gates only, not for notes).
The patch is a bit stripped down (synth wise) to demonstrate the sequencing feature. the variations illustrate some the possibilities of the delay lines.
Enjoy.
/Dasz
Clk_MIDI_DDL_DZp.pch2
 Filename:  Clk_MIDI_DDL_DZp.pch2
 Filesize:  2.86 KB
 Downloaded:  1882 Time(s)
