today> Twyndyllyngs Chez Mosc
Advice for a G2 patch
Page 1 of 1 [12 Posts]
Jackout
PostPosted: Sun Aug 30, 2009 10:40 am    Post subject: Advice for a G2 patch Reply with quote  Mark this post and the followings unread
Guys, I'm trying to recreate a sound using the G2 and was wondering if you could help. I'm trying to make something that sounds as rich and detailed as the main stab / lead in this:
http://www.youtube.com/watch?v=EwXqGJ_A9bw
If you can point me to any G2 patches that you know of I'd be very grateful
Oli
PostPosted: Sun Aug 30, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I sent the link to someone, as I thought it may be his kind of tune. He reckons that kind of sound can be done with a DX7 and a Space Echo, which he used to own. I think there is some filtering being done too, though.
Good good study, day day up!
Jackout
PostPosted: Mon Aug 31, 2009 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers captain, I'll patch up a DX7 in my G2 and have a play. The sounds have a great texture to them that I like.
Oli
PostPosted: Mon Aug 31, 2009 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, very nice sounds. Chilled, ambient, floating... I've actually wondered about how to patch those sounds before. Maybe you can crack the secret.
Oli
PostPosted: Tue Sep 08, 2009 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any progress? Does FM seem to get you there?
Oli
PostPosted: Thu Oct 01, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have a look at this youtube clip of a DX100, around 1:41 onwards. Is that the kind of sound you are after? This was posted by the guy who suggested a DX for this patch. This clip was not a response to your question though, just something he happens to have online.
Jackout
PostPosted: Mon Oct 05, 2009 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
BINGO! Thanks! So the DX100 it is then. I've been patching a bit with a DX7 patch in my G2 and am struggling to get away from bell-like sounds and into the more gritty sounds I'm after.
What is the difference between a DX7 and a DX100? I'm not sure.
Audio files: 281
PostPosted: Mon Oct 05, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The DX7 had 6 operator FM, whilst the DX100 was simplified 4 operator FM
To get more gritty sounds you need to increase the FM modulation depth and maybe add some feedback, then play with the pitches of the modulating oscillators, lower pitches tend to produce buzzier sounds
Oli
PostPosted: Mon Oct 05, 2009 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
From memory, I think the 4 op versions had additional wave forms for FM, not just sine. Perhaps square or others? I think that could be confirmed with a manual.
Audio files: 281
PostPosted: Mon Oct 05, 2009 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the later 4 op synths like the DX11 and TX81Z had other waveforms, but the earlier 4 op synths like the DX21, 27 and 100 were just sine waveforms still
mestlick
G2 patch files: 4
PostPosted: Mon Oct 05, 2009 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The first clip is gone now, but I listened to the sound at 1:41 of the second clip.
I used to use a DX100 with a Boss SE-50 thru a MS1202. That sound really reminds me of stuff I would do with that combo.
Here is a patch that is close, but not quite right. OscPM1 and 2 are the main part of the sound. OscPM3 can be brought in with the mod wheel (that's a DX100 trick since there is no filter).
Most DX100 sounds can be recreated with OscPM and ADSR with some mixers if necessary.
The FX in the clip sounded like delay into reverb into phaser, so that's what I put there.
The digitizer and overdrive are to simulate the DX100 output.
The feedback compressor with overdrive and filter is to make it sound a little dirtier.
There was a ton of noise in the clip, it might help to mix in some noise somewhere in the FX area.
I don't think I got the Osc ratios correct or the envelopes fast enough. There are definitely some artifacts from fast envelopes on the DX100 that I haven't figured out how to model. It might be necessary to digitize all envelope signals and oscillators to get all the aliasing.
dx100 delayphase.pch2
 Filename:  dx100 delayphase.pch2
 Filesize:  2.39 KB
 Downloaded:  1305 Time(s)
Jackout
PostPosted: Tue Oct 06, 2009 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that patch. The original track is below and I've added a couple of variations to your patch which kind of take me in the right direction.
02. Stalker - Redlamp 8b.mp3 - 11.62MB
dx100_delayphase_119[2].pch2
 Filename:  dx100_delayphase_119[2].pch2
 Filesize:  2.5 KB
 Downloaded:  1587 Time(s)
