 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
Interactiv logic delay
Page 1 of 1 [2 Posts]
steampump
G2 patch files: 14
PostPosted: Fri Jan 28, 2005 4:09 pm    Post subject: Interactiv logic delay Reply with quote  Mark this post and the followings unread
The idea is very simple and my first purpose was only to create a delayed trigger to start osc and filter in a predefined sequence. The pacht can do this with some modifications but in the state it is now , it does something completely different. I have add controlers and create a interactiv loop trigger. Something like a " chain gater". The pacht has only a very simple osc with a filter . The structure can be addapted to any more softicate synth.
How to use it ? You need to assing the loop start button to a midi control. When it is on , you have only to play some short notes on the keyboard. Var 1to 7 are just samples var 8 stop the sound. To stop the loop you need the " Loop button " or use the editor.
To see how dramaticly the sound can change , you need 2 slider to control the delay time and the pulse lenght (morph). Not worth to use some controlers for the filter and the lfo . That my point of view of interactivity.
osc1synth_1gates.pch2
 Filename:  osc1synth_1gates.pch2
 Filesize:  2.98 KB
 Downloaded:  1530 Time(s)
Artworks Music Computer
Audio files: 232
PostPosted: Sat Jan 29, 2005 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting. I'd like to hear some music you make with this when you get to that stage...
