Sander_k
Joined: Jan 28, 2005 Posts: 57 Location: The Netherlands
G2 patch files: 16
Posted: Sun Feb 06, 2005 6:37 pm Post subject:
Prblms with G2 (PC reboots / performances not loaded corr) ! |
some strange things are happening.
I'm working in my sequencer (cubase sx2.0) and have both midi in/out connected to a midex8 and a channel assigned to the G2x by adding a channel and selecting it and midi-local off < a quite normal situation right?
I dail-up a performance, 1: early autumn for instance. What happens is that all patches in the perf. are loaded incorrectly; the G2X messes up by giving me all kinds of weird patch combinations.
Only when i disconnect the G2X's midi in from the PC and then re-dail the performance it's loaded correcty. When doing this all slots are assigned to midi-channel 1 in the system-settings< that could be it
Another thing, while finding out what the above could be i powered off the G2X and when doing that my PC rebooted instantly!
Pc problem or G2X problem? |
Joined: Apr 03, 2004 Posts: 23500 Location: The Netherlands, Enschede
Audio files: 262
Posted: Sun Feb 06, 2005 7:28 pm Post subject:
Two problems I think.
The rebooting thing makes no sense to me, what OS are you running ? Maybe a bad USB driver.
The weird loading behaviour looks like a MIDI loop, the G2 sending patch changes that get sent back through the PC to the G2, probably a settings issue in cubase.
Jan. |
ikk
Joined: Mar 26, 2004 Posts: 8 Location: Tampere, Finland
Posted: Mon Feb 07, 2005 7:13 am Post subject:
Re: Prblms with G2 (PC reboots / performances not loaded cor |
Sander_k wrote: |
This happens consistently on my PC too, when I switch my G2 off while the editor is not running. I run Windows XP on an Asus A7N8X-E DeLuxe motherboard.
(Now I am also a happy owner of an Apple iBook that I use for the G2 editor, so I haven't tried debugging the problem further.)
-Heikki |
Sander_k
G2 patch files: 16
Posted: Sat Feb 12, 2005 6:06 am Post subject:
No one else has this problem? It's indeed consistent.. whenever the editor is running and the G2(x) is shut off, my PC shut's off too..
I'm running Win XP and this is definitely something that needs fixing! |
Joined: Jan 31, 2003 Posts: 18012 Location: Allentown, PA
Audio files: 163
Posted: Sat Feb 12, 2005 9:51 am Post subject:
I just tried the power-off thing and my XP machine didn't blink. I am running the latest beta G2 software so my test may not do much to comfort you. Maybe if you gently rub the side of your G2 and chant ancient Viking odes you'll get a new software release with USB enhancements soon. Hey, you never know... _________________ --Howard
my music and other stuff |
Audio files: 262
General Elektrick
Joined: Apr 06, 2004 Posts: 254 Location: Berlin/Germany
Posted: Sat Feb 12, 2005 10:54 am Post subject:
Funny,
I hope it will help!  _________________ Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage. |
