6 voice unisono
Page 1 of 1 [2 Posts]
3phase
G2 patch files: 141
PostPosted: Fri Mar 11, 2005 1:52 pm    Post subject: 6 voice unisono Reply with quote  Mark this post and the followings unread
This Patch is setup for slot a use... Midi Notezone Modules double the midiinput.. A stat module with a control seq generates diferent values for any voice played that can be used to alter pitch/filter aso. to generate unisono kind of sounds
6Vce Unison Brss.pch2
 Filename:  6Vce Unison Brss.pch2
 Filesize:  2.61 KB
 Downloaded:  2033 Time(s)
Audio files: 303
PostPosted: Fri Mar 11, 2005 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would have ended up probably with using an amplitude envelope in the effects section of a six voice patch.
This though is an interesting way to use (and demonstrate) the use of the NoteZone module, it seems more flexible as well.
Jan.
