 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Vogon
Page 1 of 1 [5 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Mar 14, 2005 8:10 pm    Post subject: Vogon Reply with quote  Mark this post and the followings unread
My latest attempt at a bell tree, and a lot of ring modulators.
Slot A uses an interesting property of the ringmod. If you feed the same sine to both inputs, you get a sine of twice the frequency at the output.
I tried using it in a micro/macro type configuration where the level of multiple sines is AMed by multiple sine LFOs then used as a PM oscillator modulator. The result is not very interesting by itself so I added a Vogon reciting poetry and some other things.
Oh freddled gruntbuggley, thy micturations are to me
As plurdled gabbleblotchits on a lurgid bee
Groop I implore thee, my foonting turlingdromes
And hooptiously drangle me with crinkly bindlewurdles, or I will rend thee in the gobberwarts with my blurglecruncheon, see if I don't!
vogon.prf2
experimental sounds
 Filename:  vogon.prf2
 Filesize:  11.05 KB
 Downloaded:  2141 Time(s)
Audio files: 232
PostPosted: Mon Mar 14, 2005 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one's out there, Ian... Shocked
jamos
G2 patch files: 41
PostPosted: Mon Mar 14, 2005 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I like this.. very inspiring. Except for that nasty crackling. Is that intentional?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Mar 15, 2005 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the Vogon is eating a packet of crisps. This probably makes more sense if your familiar with Douglas Adam’s Hitch Hikers Guide Trilogy (which goes down hill after the forth book IMHO). Anyway crisp packet crackling is Slot B 3rd column, it has its own output so can be switched off easy.
cebec
G2 patch files: 31
PostPosted: Tue Mar 15, 2005 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i really enjoy how weird, dark, and syrupy this one is!
