EvolLove
Posted: Mon Sep 17, 2012 2:32 am Post subject:
Step Sequencer Problem |
Hallo Everybody,
my G2 has a strange beaveour in the following situation:
- When a note sequencer is running it's sequence to control the pitch of the oscillators and I put a new module on the patch, without connecting any cables, the timbre of the sound previously programmed mutates. This happen only when a sequencer is controlling the pitch of the synthesis structure. Otherwise, when I play the notes on the keyboard, everything works fine.
If anybody has some idea of what's happening, I would be very grateful to him of letting me know.
Many thanks in advance. |
iPassenger
Joined: Jan 27, 2007 Posts: 1051 Location: Sheffield, UK
G2 patch files: 78
Posted: Mon Sep 17, 2012 4:33 am Post subject:
A new module causes the patch to recalculate.
My guess is if you have more than one OSC at the same pitch but not synced, then the reloading/recalculation of the patch is changing the relative phase of these OSC too each other. This is probably changing the sound of the sequence, if you are FM-ing, you can get a similar result but it is caused by the same thing, the relative phase of the OSC is changing the resulting timbre. _________________ iP (Ross)
EvolLove
Posted: Mon Sep 17, 2012 5:51 am Post subject:
Thank you very much for your quick and right reply but unfourtunately the issue happen also when there is just one oscillator and no FM.. |
iPassenger
G2 patch files: 78
EvolLove
Posted: Mon Sep 17, 2012 11:13 am Post subject:
It doesn't happen on a specific patch and, I've just discovered, it doesn't happen all the times.
I also have another similar problem, that maby can be related and could help you understand the whole situation:
- I noticed this problem to happen only in the attached patch "Drum". After a while I start the performance the kick drum lowers it's power (something like a filtered effect). This problem doesn't happen all the times too. In the performance I have some patches receiving midi notes from Ableton Live's sequencer and everything is sincronized with the midi clock of my Allen & Heat Xone 2D.
Description: |
 Download |
Filename: |
Drum.pch2 |
Filesize: |
6.83 KB |
Downloaded: |
3321 Time(s) |
Description: |
 Download |
Filename: |
Drum.pch2 |
Filesize: |
6.83 KB |
Downloaded: |
3338 Time(s) |
EvolLove
iPassenger
G2 patch files: 78
Posted: Mon Sep 17, 2012 11:58 am Post subject:
I can't hear the problem you describe.
The first triggered sound is sometimes a bit muted when it recalculates but i think this is due to a smoothing of the level as it fades out and fades in the patch following the calculation, to prevent loud clicks I guess. _________________ iP (Ross)
