 Forum index » Clavia Nord Modular » G2 Patches - Completed » Bass
simple analog bass synth
Page 1 of 1 [3 Posts]
G2 patch files: 626
PostPosted: Tue Apr 12, 2005 4:18 pm    Post subject: simple analog bass synth Reply with quote  Mark this post and the followings unread
Thanks to Rob for showing how to tame DIY filter resonance, this simple 1 VCO bass synth has a 18dB low pass with a level scaler module used as a soft clipper. This gives very fine control of upper and lower clipping shape, small -dB values work best for valve/OTA type clipping. Also from one of Rob’s ideas, the basic wave can be alternated between pos and negative values and combined with diode clipping, gives a good selection of interesting waveforms from a single saw.
Aynalog.pch2
Analog Bass
 Filename:  Aynalog.pch2
 Filesize:  1.46 KB
 Downloaded:  3062 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Apr 12, 2005 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the words of mosc - "It's a keeper" Very Happy
Nice warm analog sound. Definitely gonna be playing around with this one.
General Elektrick
PostPosted: Wed Apr 13, 2005 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing, this is a very usefull patch!
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
