sequencing external gear from G2
Page 1 of 1 [3 Posts]
richard s
PostPosted: Fri Apr 15, 2005 11:26 am    Post subject: sequencing external gear from G2 Reply with quote  Mark this post and the followings unread
Can somebody guide me through the basic principles of sequencing an external synth - in my case an andromeda - using the G2?
Richard
Audio files: 262
PostPosted: Fri Apr 15, 2005 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
How basic would you like it to be ?
Attached is a very basic patch that you could try some things with. Like trying what the knobs on the note send module do, or what the T button on the the top sequencer does.
When you want longer sequences some trickery is needed to chain sequencers, the manual seems to have incorrect examples.
Jan.
bas-ext-seq.pch2
very basic external sequencer
 Filename:  bas-ext-seq.pch2
 Filesize:  1.46 KB
 Downloaded:  2255 Time(s)
337is
PostPosted: Sat Apr 07, 2012 8:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, I'm currently trying to use the G2X to sequence a SEMPRO. I can't seem to get useful results out of Note feature on the NoteSend module. Like even if I throw a fast rate LFO on it, I can hear much of a change in pitch.
What I'd really like to do is set up a simple 8 step sequencer in the G2X which will allow me to use to use the hardware buttons to turn trig/gate on or off, and then use the corresponding knob to adjust pitch on the fly. Can such a thing be done? It seems like once I use trig, all pitch control flies out the window. And if I use gate then I can't accurately control the rhythmic pattern as they start to mush together.
Any ideas on how to do this?
