how do you compensate for the delay caused by a........
Page 1 of 1 [4 Posts]
Bensen Raccoon
G2 patch files: 8
PostPosted: Fri Jul 15, 2005 2:35 pm    Post subject: how do you compensate for the delay caused by a........ Reply with quote  Mark this post and the followings unread
switch module?
i have a switch module with two different logic signals on the imputs, its being switch via a midi control send module.
here is the patch.. the switch module is in red.
thanks very much for your help..
yeeeeeeeeeee ha!.pch2
 Filename:  yeeeeeeeeeee ha!.pch2
 Filesize:  4.63 KB
 Downloaded:  1599 Time(s)
It is the jigsaw, it is purple haze, it never stays in one place, it is not a passing phase.
PostPosted: Fri Jul 15, 2005 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
This shouldn´t cause any delay at all so you don´t? You might want to connect the clock´s sync to the clock devider´s reset though.
Audio files: 313
PostPosted: Fri Jul 15, 2005 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im not sure I understand you right, but I assume you have trouble with the (clock) asynchroneous tempo switching.
If so, it's easier I thinkto solve the problem at the source, in this case the midi CC snd module, where a sample and hold could be added to synchronize the midi CC sends to the clock.
This synchronization is not accomplished by the yellow input of the CC send module. The yellow input can be used to send out a CC even when the value as not changed. Otherwise values are only sent when the blue input changes.
Another solution would be to be a synchronizing circuit around the red module in your patch, this would be more complex (but needed when the CC sender would not be in the patch but somewhere external).
BTW thre is a nice background sound going on in the patch.
Jan.
yeeeeeeeeeee_ha_.pch2
syncing example, thread specific
 Filename:  yeeeeeeeeeee_ha_.pch2
 Filesize:  4.65 KB
 Downloaded:  2890 Time(s)
Bensen Raccoon
G2 patch files: 8
PostPosted: Fri Jul 15, 2005 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
great thanks.
i changed the lfo's around, it sounds much better now.
 Filesize:  4.75 KB
 Downloaded:  1663 Time(s)
