Multi tap sequencer
Page 1 of 1 [4 Posts]
mplayer78
PostPosted: Mon Sep 12, 2005 7:20 am    Post subject: Multi tap sequencer Reply with quote  Mark this post and the followings unread
Does anyone know how I would create such a device. I want to be able to select the interval between individual steps between 1/8, 1/4 & 1/2.
Thanks,
Matt
deknow
PostPosted: Mon Sep 12, 2005 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
...i assume you mean that you want 1 sequencer, and to have differant steps on differant outputs?
the easy ("expensive") way, i think, is to use a clocked delay.
the better way is to use a s/h or t/h module, and use a clock divide to set your offset.
deknow
PostPosted: Mon Sep 12, 2005 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I just created a sequencer that has the length of each step controllable. It's in slot D of the performance in the response to this thread:
http://electro-music.com/forum/topic-7757.html
I use one sequencer to set the length of the step. That controls the rate of an LFO, which is then used as a clock into the next step. A note sequencer runs in tandem to carry the actualy note info, but you could use any sequencer in it's place...
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Sep 17, 2005 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I like to use a 2nd sequencer as a groove source while the 1st one is used to trigger the groove (and select it too). I used it in Mystica_DZ.pch2 in the soundset.
This way the 2nd sequencer(s) can do some way cool stuff. the attached patch illustrates this (but makes no sound).
/Dasz
SeqTrigGate_DZ.pch2
1st sequencer as trigger, 2nd sequencer as groove or mod of 1st.
 Filename:  SeqTrigGate_DZ.pch2
 Filesize:  2.18 KB
 Downloaded:  1152 Time(s)
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
